Water Blades
Old Mar 19, 2008 | 02:16 PM
Gavin E-Cos's Avatar
Gavin E-Cos
Default Water Blades
Has any one used these rubber water blade things for removing water from the car after its been wash?
My concern has always been, do they scratch the paint work?
What is your opinion, and which one would you reccomend?
Thanks,
Gavin
Old Mar 19, 2008 | 02:18 PM
AlexF's Avatar
AlexF
If you are sure there is no dirty at all then they are fine....
BUT
There is always the risk of a spec of grit causing a scratch.
A waffle weeve drying towl is a better solution - but you really need 2 to do a decent job.
Alex
Old Mar 19, 2008 | 02:54 PM
Smiggy's Avatar
Smiggy
I've got one, works quite well. Just make sure you don't put it down on the ground or if you do make sure that the blade has no small stones or debris on it and it will be fine.
Got mine out of Costco years ago, guy was there doing a demonstration and gave some away.
Old Mar 19, 2008 | 03:15 PM
C4llyT's Avatar
C4llyT
Does work well, but ideally you wouldn't use it.
Have the paint well prepped, then well sealed, then after rinsing car off after washing, remove hose end and rinse like this.
Then use a drying towel, Sonus are very good.
Ideally spray the car with Meguirs Last Touch before drying, leaves a better finish and helps prevent water spotting/staining.
Old Mar 19, 2008 | 03:20 PM
BM08's Avatar
BM08
Was thinking about this myself as currently im buying chamois leathers at Ł10 a pop every 6-8 months because they go brittle
Old Mar 19, 2008 | 03:26 PM
C4llyT's Avatar
C4llyT
Fuck the chamois, try a towel and you'll wonder how you put up with all that ballache.
Last time I washed mine, dried whole car, then went to wring towel out, couldn't get a drop out!
Used to hate drying, piece of piss now.
Old Mar 19, 2008 | 03:33 PM
BM08's Avatar
BM08
What are these "towels" called? links?
Old Mar 19, 2008 | 03:34 PM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
I use one all you need to do is have a cloth in your other hand and after everytime you wipe water off your car just wipe the edge of the blade - job done then finish off those arkward bits with a microfibre
Old Mar 19, 2008 | 03:36 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Seconded
Old Mar 19, 2008 | 03:38 PM
Kevin B's Avatar
Kevin B
We use one and I think they are pretty good, certainly get most of the water off and can just finish up with a chamois etc.
As long as the car is clean (free from grit) you should be alright.
Old Mar 19, 2008 | 03:42 PM
lammylama's Avatar
lammylama
As said before make sure there is no grit whatsoever in the groove along the edge of the blade......I made this mistake on our mondeo and i put 3 scratches along the door ....mmmmm nice...NOT,luckily they polished out!!!!
Old Mar 19, 2008 | 03:46 PM
mad_on_Series_one's Avatar
mad_on_Series_one
toodle pip !
i use my wiperblade sometimes
Old Mar 19, 2008 | 03:47 PM
BM08's Avatar
BM08
You must love your car.......... NOT
I expect it works but sod that, its not made for drying paint work is it
Old Mar 19, 2008 | 03:59 PM
AlexF's Avatar
AlexF
These towels are called Waffle Weeve - like I said above
Old Mar 19, 2008 | 04:01 PM
taycoss's Avatar
taycoss
http://www.polishedbliss.co.uk/acata...ucts-wash.html
get the poorboys waffle weave towel.......amazing and service from there is great too.
AlexF's Avatar
AlexF
I like these ones from this supplier
http://www.detailedobsession.com/cat...products_id=31
Old Mar 19, 2008 | 04:02 PM
AlexF's Avatar
AlexF
you beat me to it!
Old Mar 19, 2008 | 04:04 PM
Brian's Avatar
Brian
I use a water blade i bought a Auto Glym one a few years ago always put it in a bucket of hot water first to clean it and it also softerns the rubber a bit
Brian
Old Mar 19, 2008 | 04:19 PM
BM08's Avatar
BM08
cheers for the links lads, cheaper than a decent leather aswell
Old Mar 19, 2008 | 04:33 PM
AlexF's Avatar
AlexF
Better than one too as it cant scratch the paint.
Your not using a sponge are you>?<
Old Mar 19, 2008 | 04:49 PM
Gavin E-Cos
Thanks for your replys, mixed views.
I have been using Meguiars water magnet towel, but wonders if the blade was any quicker to use.
I may try a blade and see how I get on.
Thanks.
Gav
Old Mar 19, 2008 | 05:03 PM
C4llyT's Avatar
C4llyT
http://www.cleanyourcar.co.uk/microf...2/prod_84.html
What I use, can't go wrong with Sonus, German.
Blade is great at drying, but towel is less risk, more wise choice.
You'd still have to towel dry with a blade, to get best possible finish, which ideally you'd use last touch or similar.
Blading first would leave car too dry to work the towel easily.
I did use a blade for a long time, but towel takes very little time, so no need for the risk.
Last touch: http://www.cleanyourcar.co.uk/detail.../prod_225.html
Diluted makes 8 litres, so good for the money.
So many uses, claying, polishing and waxing to help removal, and to finish off to collect any residue dust.
When machine polishing to prime the pads.
Quick wipe of wheels to help shine a little.
When wet sanding.
Old Mar 19, 2008 | 05:09 PM
BM08's Avatar
BM08
yeah why? i shouldnt be using that then?
Old Mar 19, 2008 | 05:13 PM
C4llyT's Avatar
C4llyT
Nah, lambswool washmitt: http://www.cleanyourcar.co.uk/washin...-/prod_32.html
A lot better for paintwork, sponge drags dirt all over the surface.
Old Mar 19, 2008 | 05:29 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Just ordered two - thanks for the recommendation !
What should I be ordering to clean the car with, as I do use a sponge at the moment .
Old Mar 19, 2008 | 05:36 PM
C4llyT's Avatar
C4llyT
Try looking above Mike, lambswool washmitt.
Once you get started end up spending a fortune!
Gonna have to look at doing it for a career to pay for all the gear...
Old Mar 19, 2008 | 09:12 PM
NathR's Avatar
NathR
I personally don't use them on my car (I do on anyone elses or the work van though ) I'm always concerned they'll scratch.
I use a lambswool mitt, Poorboys shampoo and Poorboys waffle towel thingy! IMO Autoglym synthetic chammys are still the easiest option but the waffle towel, again, prevents swirls/scratches.
For any advice I would advise a chat with Gareth (of detailed obsession) I spent hundreds of pounds with him last May on bufty stuff along with a Porter Cable but I still haven't had time to use it!! Top bloke though.
Old Mar 19, 2008 | 09:19 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I've just ordered some bits off of Gareth and will be using his services again when I want more stuff
Old Mar 19, 2008 | 09:32 PM
MATCOS's Avatar
MATCOS
I use Gareth too and these towels are top bloody notch
Old Mar 19, 2008 | 09:39 PM
MATCOS's Avatar
MATCOS
Mike I am going to frame this
You cleaning your car properly
I use 2 buckets one with a grit guard (this stops the grit getting onto your wash mitt when you put it in the water)
I wouldn't use a sponge at all, get yourself a decent wash mitt, again Gareth will sort you out I'm sure, I have a few and don't use the same one that I use to do my paint work with the one I do my wheels etc.
Just from changing from sponges and chamois, to the above you will find it much easier and get a much better job
Old Mar 20, 2008 | 08:11 AM
Mike Rainbird
Caraholic
Tossers, you've just made me spend over Ł60 !
Old Mar 20, 2008 | 08:20 AM
Bullett's Avatar
Bullett
it will be going up my friend! once you start it snowballs.i use meguiars but thats because i get it at cost price through work.i still have well over 400 pounds worth though
Old Mar 20, 2008 | 09:41 AM
AlexF's Avatar
AlexF
MIKES A FUCKING BUFTY AT HEART lmao
Two buckets and a lambs wool mit are what you need to wash a car! After 14k miles and 19 months my MINI GP had superb almost swirl free paint - better than other gp's with less than 2k miles on!
Method:
Fill 1 bucket with soap and water and the other with just water
Damp car down
Wash one section at a time starting at the top and working down towards the front. Leave the back till last as its usually gritty as hell.
Use the mit to wash one pannel at a time - then rinse the mitt in the water bucket before putting it back into the soap bucket.
Its easy when you get use to it and it does so much less damage to your paint its not true!
Alex
Old Mar 20, 2008 | 11:51 AM
Mike Rainbird
Caraholic
Make that Ł70+ !
Old Mar 20, 2008 | 12:00 PM
MATCOS's Avatar
MATCOS
Good work Mike
Old Mar 20, 2008 | 12:26 PM
The Rapid 1's Avatar
The Rapid 1
I'll have to ask the Polish boys at the local car park what they use on mine
Actually when I bother to clean it myself I use that Flash drying system that sprays deionized water to "dry" the car, and it actually works
My last couple of cars have been black and you know how it shows all the water marks, well the deionized water washes away all the "dirty" wash water, and it is only the residual dirt left in the water that leaves the marks, the deionized leaves nothing, not on black paint, not on glass, I couldnt believe it first time I used it, nor could my sis who said I was wasting my money, and she is a bit of a closet bufty lol, and even she was impressed !
And whats more you dont touch the car at all, if you worried about marking it with grit etc
http://www.freshliving.com/flashcarwash/home.htm
Steve
Old Mar 20, 2008 | 01:55 PM
Gavin E-Cos
Sorry to start this thread Mike, I have mostly Mergiurs products and they do work so well! - but the costs soon add up.
Does this mean we will see a clean shiny car on Tuesday?
Gav
Old Mar 20, 2008 | 02:24 PM
Mike Rainbird
Caraholic
Gav
If the weather is good on Tuesday so I can be bothered to clean it - yes .
Old Mar 20, 2008 | 03:32 PM
gingeRS's Avatar
gingeRS
mike i take it you contacted Gaz7 off here....as detailed obsession is his business and he gives nice discounts for PF members
Old Mar 20, 2008 | 03:55 PM
Graceland's Avatar
Graceland
Team HOTHOT!
If I had known that I would not of bought via Ebay and gone direct
