astra gte oil switch question
im currently putting an astra gte digi dash in my car,what i want to know is how does the dash read the oil pressure from the engine,if i got the pressure switch from a gte would that then read the oil pressure atall or does the dash take the reading from a different sensor on the engine on the gte
would i have to get it from a specialist place then,i went to my local motorist centre and they list a switch but has only got 1 terminal on it,which i pressume would be for the oil light or is that the switch i need as it was listed as the gte item
andrewmctiernan
Sep 8, 2015 03:05 PM
