who makes brake disc/seperate bells
tony,i need two sets made up for my mitsubishi,315mm and 330mm,had a set made by someone in birmingham area back end of last year and they are a complette fuck up!!hence why i asked marin if he makes them himself or gets an outside company to do them,would hate to think it was the same company as they are close to reyand.
would rather have somebody i know do them proply mate if you have time.
i have a KA.
Tim, why don't you name the said company as I don't want anyone questioning the quality of my bells and brackets
I have seen other companies efforts, some even send them out un-anodised!!
Not sure if you realise but Birmingham is quite a big place with many engineering shops .... I make lots of custom bell and brackets (4 sets this week so far!!) and have had NO complaints.
they were given a damper,upright,wheel,calipers,discs etc,a set of 330mm bells already made the correct offset but decided to alter the offset by almost 10mm because one of there contacts said he had "heard" that that was correct,so £2600 later!!! i end up with brakes that dont clear the wheels because the offset has been moved outboard even though they had the exact spec 330mm bells sent to them off me that we split new!!
and spent almost 3 months doing this and yes i had to wait for anodising so maybe the same folk!!
but definatly was not reyland,or i would not of had this bloody problem iam sure of that.
Tim what is it exactly you have / want ? I will call in next time i'm up for a look.
No need to post unless its urgent, in fact I have some 2 piece 315mm Evo 5-9 ones in stock I will bring them up.
They are not anodised BTW as they are a development set.
315's were done in a rush for mark for grizdale,will show you when you call in to collect your nuts!!
jessie_rs
11
Jun 3, 2019 04:57 PM
Jack and the Beanstalk
Sep 13, 2015 03:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
