what causes tramlining
Old Mar 18, 2008 | 08:36 PM
Lee Reynolds's Avatar
Lee Reynolds
Default what causes tramlining
Ive heard this lots and had it lots when my S2 was on 17's, but never asked 'why it does it'? Why does bigger wheels make it do this?
Old Mar 18, 2008 | 08:47 PM
Ginge !'s Avatar
Ginge !
just finding my feet
its usually down to worn bushes and worn control arms and wheels blamed i belive
when my BMW was tramlining it was worn suspention rather than the wheels
Old Mar 18, 2008 | 08:49 PM
cossie604's Avatar
cossie604
imo bigger/wider wheels give more leverage against already tired bushes hence why tramlining is more noticable when you swap to bigger rims.
Old Mar 18, 2008 | 08:51 PM
C4llyT's Avatar
C4llyT
Also directional tyres, which I guess are the norm more on bigger wheels.
Old Mar 18, 2008 | 08:52 PM
Lee Reynolds
My front end bushes were all renewed and i rebuilt the hubs etc....
Old Mar 18, 2008 | 08:56 PM
Ginge !'s Avatar
Ginge !
and the lower arms ??
steering rack ???
top mounts ???
tyres used ???
these ALL make a difference, but again just the larger size will affect the car anyway, fit
Old Mar 18, 2008 | 09:06 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need to make sure the centreline on the replacement rims are the same as your normal rims
and seeing as most are only skiiny rims that get replaced with wider ones this might explain the cause
that said, i noticed that when swapping over to 8" rims from 7.5" ones caused the steering to get noticably lghter
Old Mar 18, 2008 | 10:24 PM
Lee Reynolds
steering rack ???
top mounts ???
tyres used ???
am going back about 8 years now but iirc they were some falken tyre of some sort!
Old Mar 18, 2008 | 10:28 PM
kiddie's Avatar
kiddie
Bit scary on a bike at 100+ on sunken tractor 'tramlines' I shat myself!
Old Mar 18, 2008 | 10:41 PM
cossie04's Avatar
cossie04
Had this with the T5, worn lower arm bushes and track rod ends. Alot better when replaced but still did a little bit...
Old Mar 18, 2008 | 10:43 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Wide front wheels, suspension play, bad geometry
Old Mar 18, 2008 | 10:44 PM
Ginge !'s Avatar
Ginge !
you forgot to add " old car "
Old Mar 18, 2008 | 11:09 PM
marco polo's Avatar
marco polo
mainly big wheels and tyres can cause this also
my car is all over the shop with the r888 in the damp never had an issue with the goodyear f1's
Old Mar 18, 2008 | 11:13 PM
CheekyTequila's Avatar
CheekyTequila
Stroking one off the cuff
Inside lane on the approach to the m4 junction on the M25 - go there to experience tramlining...its great
Old Mar 18, 2008 | 11:18 PM
jpblue's Avatar
jpblue
Tramlining, as the name implies is a tendancy for the wheels of a car to follow the longitudinal ruts in the road as found in highly worn lanes or where heavy truck traffic is common, funnily just like a tram following its tracks. Its exacerbated by wider tyres as they hit more irregularities and varied offsets which affect suspension angles. Worn components only allow tramlining to be more pronounced rather than causing it. performance wheel angles such as camber and caster make it harder to manage once the car begins to follow the ruts.
Cheers,
Justin p
Old Mar 18, 2008 | 11:20 PM
CheekyTequila
That must have come from Wik Wik Wikipedia
Old Mar 18, 2008 | 11:46 PM
jpblue's Avatar
jpblue
nope, nope, nope it didnt.
Old Mar 19, 2008 | 12:08 AM
BM08's Avatar
BM08
very good, your reply was the one that made most sense
2Litre
20
Nov 11, 2013 01:26 PM
col93saphcos
38
Apr 22, 2010 05:07 PM
scoooby slayer
Dec 29, 2009 11:17 AM
TurboShed
Mar 28, 2008 11:05 AM
Sausage
Nov 19, 2007 06:31 PM
