Steering knucke donut 3dr
Old Mar 18, 2008 | 02:31 PM
rsnissan's Avatar
rsnissan
Default Steering knucke donut 3dr
Are these still available or is there an alternative option
Old Mar 18, 2008 | 03:32 PM
bpspa's Avatar
bpspa
I'm looking for one of these currently just phoned up Ford who say it NLA but they would need to ring around to see if anyone has one. Quoted Ł96 for it though.
Let me know if you find one and where from and how much
Old Mar 18, 2008 | 04:17 PM
iansoutham's Avatar
iansoutham
OCD Victim
Speak to Neil Adderley (Stixy) on www.fordsierraclub.co.uk.
He breaks Sierra models and has more than likely got a few lying around.
I'd be quick though, he is having a clearout ATM.
Old Mar 18, 2008 | 04:41 PM
rsnissan's Avatar
rsnissan
there must be some other option
mine was a mint new ford one but my exhaust mani leaked a bit and has now killed my one lol................ARSE
looks like i will have to get a bit more creative
Old Mar 18, 2008 | 07:11 PM
Get on the web for LANDROVER bits, as a almost identical one is fitted to these, but MUCH stronger, just needs drilling and bolting.
NB this is for the flexy bit NOT the knuckle on the end of the steering shaft, as I assume this is what you are reffering to ?
Old Mar 18, 2008 | 07:13 PM
cozzycol's Avatar
cozzycol
Got mine from Paul at North yorkshire RS Spares
was second hand but good as new
Col
Old Mar 18, 2008 | 07:40 PM
Simmo's Avatar
Simmo
Gonna replace mine too while I can get to it easily... Apparently you can use one from a Mk1 Escort with minor mods...
...Superflex do an uprated poly item (part no. SPF1159K) about Ł35ish I think.
Obviously old one has to be drilled out and new one fixed with short bolts... but being poly you won't have to replace it again!!!
This is what i'm gonna do anyway...
Old Mar 18, 2008 | 10:22 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i phoned ford today about other bushes and asked about this to be told it was in stock at Ł1.??!
post a pic of the donut itself?
Old Mar 18, 2008 | 10:30 PM
bpspa's Avatar
bpspa
does the bush come off then as I though it was a one whole flexible coupling
have you got the finis code?
Old Mar 19, 2008 | 10:48 AM
HBS's Avatar
HBS
The rubber donut looks very similar to the one fitted to E30 BMW´s. Worth a try I would think.
Old Mar 19, 2008 | 11:57 AM
cozmeister's Avatar
cozmeister
More boost Igor!
I got a new VICO (VECO?) one from ebay last year when mine fell apart like an onion.
The rubber part between the two shafts is replaceable.
Old Mar 19, 2008 | 07:32 PM
lee2cossies's Avatar
lee2cossies
Just replaced the one on my saff,cost Ł10 from motor factors.Had a look at a land rover discovery one and it looks the same.
Old Mar 20, 2008 | 09:48 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
right im not very clued up here and thought i needed what you said! i've just come from ford where i bought a rubber donut, washer and clip thingymabobber. they are not part of the coupling tho. the coupling (as said above) is about Ł96 and now obsolete!
my bits were Ł3.30 odd NEVER bought parts so cheap
Old Mar 20, 2008 | 10:47 AM
rsnissan's Avatar
rsnissan
Lambchop can you post a pic of the part you have got please!
the bit I am after is round rubber bush type thingymabob near the bolt with blue paint in the pic
Old Mar 20, 2008 | 11:33 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
andy
i'll post a pic from home later nae bother
Old Mar 20, 2008 | 02:11 PM
Ridgey's Avatar
Ridgey
Lambchop
would you post the finis or part codes for the bits you bought as well please
Old Mar 20, 2008 | 02:52 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Originally Posted by Dave Ridge
Lambchop
no sweat mate they are on the receipt hopefully!
Old Mar 20, 2008 | 09:00 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
lambchop - it sounds like you've bought the bulkhead bearing. It's a ring and a collar with a triangle shaped hole in it?
You need that if you have play in the steering column. You check by holding it close to the end and wiggle it, any play change it.
Old Mar 21, 2008 | 07:22 AM
I checked with FRAUD yesterday, no parts available other than the mentioned bulkhead bush, at about Ł3.50p.
Old Mar 21, 2008 | 05:08 PM
mechanic28's Avatar
mechanic28
so how do u change said bulkhead bush,got my engine out at the mo,and my column has some play in it!as it nice and easy to get to now might as well change it now!is it striaght forward?
Old Mar 21, 2008 | 06:31 PM
Easy to do, even with engine in.
Just move bottom part of column out of the way by removing column or sliding lower part up the sleeve, then take plastic part of the end, then prise out centre plastic piece of bush from the rubber outer in bulkhead, then remove rubber piece.
Re install in reverse order, making sure inner plastic piece of shaft is pushed fully into plastic piece within the rubber outer in bulkhead, then push the CLIP down to hold in position.
Old Mar 24, 2008 | 07:32 PM
Ridgey's Avatar
Ridgey
Are we talking about the item shown in the picture at the top of the thread ??
I'm slightly confused... i know not easy !!!
Old Mar 24, 2008 | 07:35 PM
rapidcossie's Avatar
rapidcossie
Make sure you heat shield the new ones you fit
Old Mar 28, 2008 | 07:08 PM
bpspa's Avatar
bpspa
rsnissan, have you had any joy on this yet?
Old Apr 1, 2008 | 11:35 AM
rsnissan's Avatar
rsnissan
No mate I have not looked at this yet
I am wondering if i cant just take the rubber bush out and make something else fit? from a polybush maybe?
Old Apr 1, 2008 | 12:43 PM
bpspa's Avatar
bpspa
Andy,
I have taken my bush out now and have just ordered the Superflex one as in a previous post as I was having trouble finding one form my local motor factors as they don't stock them so couldn't have a nosey about. It should be here by the weekend so will have a go fitting it then.
I did see one on ebay for a MK2 Granada that looked very similar (the finis code they quote doesn't bring up anything), also Microcat listed various Finis Codes for the original part, the ones I got and the description are
6662306 - One listed for the 2wd saff
6662305 - OHC, or Cologne V6 or Peugeot Diesel 2.3 Less power steering
6662312 - Peugeot diesel 2.3 RHD, GB with power steering
1630797 - D, 2wd
6653228 - GB, 4wd
Just waiting on Peugeot to get back to me on whether they have one, also awaiting a response from Powerflex to see if they have anything.
Will keep you posted on how I get on
Old Apr 1, 2008 | 06:22 PM
philram's Avatar
philram
Mulechild
i took mine out and made a solid piece to replace it out of alloy. made not difference to the way it drove and its fit and forget.
Old Apr 2, 2008 | 06:51 AM
bpspa's Avatar
bpspa
I did wonder whether the bush was needed as after viewing a few other UJ's and seeing they don't have bushes I was starting to wonder if it was needed.
Old Apr 2, 2008 | 09:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the steering intermidiate shaft shouuld be the same for all sierra/granadas without the adjustable column
or even with the adjustable column come to think of it
i know that the 4wd ones differ massivly and you can't swap them over s they are too long
Old Apr 3, 2008 | 10:16 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
shit i forgot about this! i remembered as i went back to ford this am and ordered the 4th piece of 4 on this puzzle.
yes it must be the bulkhead bearing that i have then as theres LOADS of play appeared in my steering
Old Apr 3, 2008 | 08:25 PM
bpspa's Avatar
bpspa
got home and the bush from superflex has arrived photo of the kit
this is the old joint removed from the car and bush out.
it all needs a little bit of work but you do need to rescue the two metal bushes, and push them into the two spare holes and cut to size. Then just need to drill the old fixings out, possibly get some more strengthening bars made up or see if I can get the old fixings out, oh and I need a couple of bolts
will be suggesting to superflex what to put in to make it properly fit
Old Apr 3, 2008 | 09:18 PM
CosKev3's Avatar
CosKev3
Got a new 4x4 one off the bay and got a m8 who is a welder to shorten it to the same length as 2wd one.
Old Apr 4, 2008 | 11:26 AM
Ridgey's Avatar
Ridgey
bpspa
How much was the poly bush ?
Old Apr 4, 2008 | 01:56 PM
bpspa's Avatar
bpspa
bpspa
It was Ł42 including P&P, Part No SPF1159K. Going to try and get it all fitted back together today just need to get all the old rivets and that out and then it should be a case of bolting together and job done.
Old Apr 4, 2008 | 04:36 PM
daz1968's Avatar
daz1968
I did similar to above when mine went, But I bought a land Rover Discovery coupling 2nd hand ground off the rivets, then did the same with the ford one and bolted it together with 12.9 cap screws, then put a dab of weld on the nuts to make sure the MOT tester was happy that it wouldn't fall off, been great since. Only cost about a tenner and a bit of time.
Old Apr 5, 2008 | 01:07 PM
bpspa's Avatar
bpspa
what year and model was the discovery did it come off as I was going to have a look but none of the scrappy's round here had any and I couldn't find a picture of one so didn't really want to take a risk in getting one.
I have put mine back together now and all looks good. One question, is it better to use locking nuts on the bolts going through to hold it together or would I be just a safe with the normal nuts and a load of thread lock as that is what I have done so far but want to make sure its right before going down the road and finding out I can't turn
Old Apr 5, 2008 | 05:51 PM
Simmo's Avatar
Simmo
Exactly what I suggested towards the beginning of the thread!!!
Old Apr 5, 2008 | 05:53 PM
daz1968's Avatar
daz1968
The one I used was from a discovery 2 about 1996 I think, just in case anyone needs to know
Old Apr 5, 2008 | 10:04 PM
Gary Osborne's Avatar
Gary Osborne
e36 m3 evo donut fits like a glove.
hope that helps . cheap as chips too
Old May 31, 2008 | 08:06 AM
jacko996's Avatar
jacko996
Anyone had any success on this part, not sure best route to take
But need to get something sorted quickly while engine is out
