Where to buy standard trailing arm bushes for a saff?
Old Mar 18, 2008 | 11:57 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Default Where to buy standard trailing arm bushes for a saff?
my rear beam and traling arms are all off at the coaters. i have poly bushes for the beam. I've been recommended to use standard trailing arm bushes.
Where is best (read cheapest )? ford or other? mr lewis maybe?!
Old Mar 18, 2008 | 12:29 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I believe two have been discontinued .
Old Mar 18, 2008 | 12:38 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
standard bushes are no longer avaliable ... Powerflex it is then...
Old Mar 18, 2008 | 12:47 PM
Mike Rainbird
Caraholic
Wouldn't recommend it - I'd try and hunt down some no matter what it took....
Old Mar 18, 2008 | 12:51 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
you are shitting me! wtf! i need the car together and moved pronto
Old Mar 18, 2008 | 12:55 PM
Mike Rainbird
Caraholic
Start hunting then! I thought only two had been discontinued, as one resourcefal chap sourced to similar ones from Aston Martin and had them turned down to fit his Sierra .
Old Mar 18, 2008 | 12:57 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
im on hold to ford parts dept. i dont need anymore hassle thats for sure! hope he comes back with a good answer...
Old Mar 18, 2008 | 01:03 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
ok inner ones available at £55.94 EACH!
outers no longer available.
wtf do i do? remove my old ones which are maybe not so good and use them?
or use poly?
how bad can polys be?
Old Mar 18, 2008 | 01:05 PM
RWD_cossie_wil
whats so wrong with the powerflex ones then?
RichardPON's Avatar
RichardPON
Rose jointed beam.
Old Mar 18, 2008 | 01:06 PM
Mike Rainbird
Caraholic
or use poly?
How bad are your outer ones? Surely given the company your work for, you have sufficient engineering contacts to be able to have some made?
Old Mar 18, 2008 | 01:11 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i'll need to check them over.
do you know what my company does? we engineer FLUIDS which i guess would fall out
i'll get on the case with mates tho...
Old Mar 18, 2008 | 01:19 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
I agree mike get the oe part no matter what
Old Mar 18, 2008 | 01:21 PM
Turbosystems
Super Moderator
they are a bush the OE part is a zero play zero resistance sphericle rose joint and are the dogs
Old Mar 18, 2008 | 01:25 PM
Mike Rainbird
Caraholic
For the petro-chemical industry - so you should have companies that you deal with that could do this .
Old Mar 18, 2008 | 02:00 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i remember looking into this with my saff.....it drove awful on polybushes so i priced up the full set of standard bushes, and tbh it was about £300...so i just added a bit more and got a rose jointed beam lol.
EDIT: because i'm a god i found my original thread, with part numbers and prices
https://passionford.com/forum/showth...light=trailing
Old Mar 18, 2008 | 02:23 PM
philram's Avatar
philram
Mulechild
has anyone got a pic of these bushes..?
Old Mar 18, 2008 | 02:49 PM
rstoughy's Avatar
rstoughy
or use poly?
Nightmare!!!
Shame i aint got any spare kicking around you could have.
Old Mar 18, 2008 | 03:13 PM
Stu @ M Developments's Avatar
PassionFords Creator
AFPMSL.
Old Mar 18, 2008 | 03:14 PM
And i agree with Teabagsystems.
Old Mar 18, 2008 | 03:28 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
how the fuck much is a friggin rose jointed beam then?
JESUS CHRIST!
Old Mar 18, 2008 | 06:55 PM
col cos1's Avatar
col cos1
yeah does anyone have a pic to see exactly which ones these are as i have full set of poly`s about to go on but have 2 brand new black standard ones there too
Old Mar 18, 2008 | 09:33 PM
charlie luciano's Avatar
charlie luciano
I managed to get four trail arm bushes for my saph £217 all in, whats all this rose joint business my ones were just four cylindracal bushes?
Luciano
Old Mar 18, 2008 | 10:00 PM
cossie604's Avatar
cossie604
To just look at the standard bushes you'd think they were just that, bushes becuase the outer seals look just like bonded rubber. Its the wieght of them that give away they are a little bit speical internaly.
I must be lucky as I bought a new outer joint from Ford around 18mnth ago...didnt realise they were now obsolete
Old Mar 18, 2008 | 10:05 PM
cossie604's Avatar
cossie604
Read thru this:
https://passionford.com/forum/showth...ghlight=bushes
Old Mar 19, 2008 | 08:51 AM
rog's Avatar
rog
Glad I noticed this post! I have a brand new rear arm but it doesn't come with bushes in it, so 'll have to get them sorted out from somewhere other than Ford then.
When are u getting your car painted silver
Old Mar 19, 2008 | 12:42 PM
rocky_robin's Avatar
rocky_robin
Fit next!!!!
You have a set of brand new mounts and that donut things at your house..............sitting under a 3dr!
Tried Graham Goode, as I'm sure thats where Davie bought that donuts things from (from memory from the reciepts)
Old Mar 19, 2008 | 12:48 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Originally Posted by rocky_robin
Fit next!!!!
Tosser
skypeller
Sep 19, 2015 09:58 PM
TrevCos
Aug 17, 2015 09:08 PM
155lee
Aug 14, 2015 11:21 AM
RIB1122
Aug 12, 2015 08:49 PM
track.focus'd
Aug 12, 2015 05:53 PM
