Mondeo V6 Lowering
Old Jan 31, 2004 | 04:42 PM
Alzay's Avatar
Alzay
Default Mondeo V6 Lowering
Help Please.
I've just had 30mm drop Eibachs put on my 98 V6 SI the car looks like it's not dropped at all if not it seems higher at the front , when the garage put the car on the ramps initally they had to use blocks to lift the front end up.
Now after fitting the lowering springs they never needed the blocks.
Now measuring from the ground to the tip of the arch is 25' the rears is 24' thats without the rear springs fitted.
The springs that came off are Ford Standard Greens as far as I'm aware although I know Ford did different setups for the V6's.
Any views on this guys?
BTW I've driven 20miles on them since fitting to bed them in.
Old Feb 3, 2004 | 09:15 PM
Fozy's Avatar
Fozy
Are they of the progressive coil variety...i.e. are there tight coils are one end and they gradually open up. If so make sure that tight coils are at the top otherwise it may not compress correctly.
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fudgey
21
Sep 30, 2015 06:19 PM
The Enigma
Sep 29, 2015 10:31 AM
