Ap 330mm Rear Brake Set Up
Am thinking of upgrading my rear breakes. I currently have a Hi spec conversion using 310 rotoes and standard calipers.
Is it worth the money and hassel? It would be the hydraulic handbrake conversion, Which im not 100% sure how it works?
Does anyone have pics of how it would look inside the car? I belive martin puts the hydraulic handbrake inside the centre console?
Any info and pics would be much appriciated
Thanks
Thanks
why?
WHY?
sense of such an rear brake?
you dont have a rear engined porsche, where all the big weight is on the rear axle, I m driving on the ring with stock rear setup, and it was fine till now.... won't change it for this year also.... you can just give very low press on the rears if you have such a big setup and then the pads won't get temp (maybe joke
WHY?
track.focus'd
Aug 12, 2015 05:53 PM
