rs turbo with Mfi XR3i Plenum
Old Mar 17, 2008 | 05:31 PM
jsXR3I's Avatar
jsXR3I
Default rs turbo with Mfi XR3i Plenum
does any one know if the xr3i plenum will work on a rs turbo engine?? thanks
Old Mar 17, 2008 | 05:49 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
Can be done, think something needs to be changed when fitting it though but im not sure =/ maybe just pipework but i have seen it done a few times before.
Old Mar 17, 2008 | 06:09 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
it wont fit straight on as its efi, but will work either change the head or adaptor plates to convert
Old Mar 17, 2008 | 06:12 PM
XR2's Avatar
XR2
sure, why not? There were several threads the last few weeks. There was a KE-Jet XR3i with cat which had a throttle body with tps or you mod the inlet to use the RST throttle (there was an adaptor plate available @ Ford) OR you use a RSi inlet, the Turbo throttle body bolts straight on
Old Mar 17, 2008 | 06:16 PM
jonnyrsturbo
thats a nice lookin engine mate!
Old Mar 17, 2008 | 06:37 PM
jsXR3I's Avatar
jsXR3I
thanks will have to try make the rs throttle fit as the 3i plenum i have, it wont fit straight on!
Old Mar 17, 2008 | 06:43 PM
XR2's Avatar
XR2
It will fit better than EFI. Both, XR3i and RSTurbo were MFI (he said that he wanted to use the XR3i MFI inlet) engines, so he just needs a throttle body with the correct tps and some new pipework...
stevierob
Sep 7, 2015 07:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
