Went to the rolling road now the results
Old Mar 17, 2008 | 10:44 AM
capri280's Avatar
capri280
Default Went to the rolling road now the results
Car spec
std engine with group a head gasket
l8 Ecu live mapped
Siemens 55lb black injectors
Coil pack
Closed loop
Group A fuel pump
map 3
TT T35 with 0.55 housing
RS 500 intercooler
swirl pot
oil breather
mongoose exhaust
It Made 335bhp and 377lbft torque
Here is a link to the results I had two car there a 16v and a 24v both are white http://www.reallymeansounds.com/report.php?event=406
How does this sound for the spec
Old Mar 17, 2008 | 12:34 PM
LHD220Turbo's Avatar
LHD220Turbo
i thought that spec would have made more power, i was thinking 360bhp ish -
Old Mar 17, 2008 | 12:48 PM
mechanic28's Avatar
mechanic28
is that ATW or flywheel
Old Mar 17, 2008 | 05:57 PM
LHD220Turbo
good point!!
Old Mar 17, 2008 | 06:19 PM
Tev's Avatar
Tev
yer i would have said it would have made more but if thats at the wheels sounds good
Old Mar 17, 2008 | 06:33 PM
capri280's Avatar
capri280
Default rolling road
no 335.8 at the fly wheel and 301.2 at the wheels
Old Mar 17, 2008 | 06:40 PM
capri280's Avatar
capri280
what can i do now to increase output from a bolt on senario
By the way i have changed the motorsport blue plug leads to red formula power leads
could this have any bearing on the power output
i had asked the people mapping to give me 380-390bhp
any advice appreciated
Old Mar 17, 2008 | 06:42 PM
Alps Pacino's Avatar
Alps Pacino
whang the boost up to 2.2 bar
Old Mar 17, 2008 | 06:45 PM
garyrs's Avatar
garyrs
unless im blind (wich i probly am) you havent stated what boost you made this power with
? wich would say if its good or bad power
gary
Old Mar 17, 2008 | 06:53 PM
capri280's Avatar
capri280
when set up at live mapping i believe it was 29 psi
i will research this fact
Old Mar 17, 2008 | 07:05 PM
Jasesapphy's Avatar
Jasesapphy
can you post the graph
Old Mar 17, 2008 | 07:35 PM
I would of thought it would be more than that.
Old Mar 17, 2008 | 09:12 PM
Gordon1's Avatar
Gordon1
Smile
301.2 atw is not bad at all only a 34.6 loss tho ?
but its the wheel power you need not flywheel
Old Mar 17, 2008 | 09:41 PM
Jasesapphy's Avatar
Jasesapphy
STU at MSD live maps these to 370-380 dependent on engine condition, so its a little low
Old Mar 17, 2008 | 09:43 PM
LHD220Turbo
mine is going to be almost identical spec, running one of Stu's chips and i want between 350-370bhp
Old Mar 17, 2008 | 09:48 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
mine is 367 @ the wheels t34 rs 500 intercooler NMS stage 1 gunship conversion live mapped
Old Mar 17, 2008 | 10:14 PM
capri280's Avatar
capri280
car was set up by stu at MSD
Old Mar 17, 2008 | 10:55 PM
155lee's Avatar
155lee
whats a norris gunship conversion?sounds fast!
Old Mar 18, 2008 | 08:04 AM
34 bhp loss, complete crap, someones telling you porkies, reckon on around 20-25%.
Old Mar 18, 2008 | 07:50 PM
davy 6457's Avatar
davy 6457
i was at the road as well and mine made 273at the flywheel and 220 at the wheels but mine is 4x4 so prob is a bigger differance cos of the extra drag
Old Mar 18, 2008 | 09:36 PM
CosKev3's Avatar
CosKev3
Lower than I expected,but good torque,bet it goes well on the road
What boost and injectors is that on????????????
Thought the Gunship was standard injectors
Old Mar 18, 2008 | 10:10 PM
rapidcossie's Avatar
rapidcossie
You will find most the similary specced cars will be within 20-30 bhp of each other and any differences will be in how the power is measured.
Old Mar 18, 2008 | 10:11 PM
col cos1's Avatar
col cos1
sorry but thats either a typing error lol
or bullshit
that makes your car 410bhp if 2wd
420bhp if 4x4 roughly
on t34 and stage 1???????????????????????
Old Mar 18, 2008 | 10:19 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
or bullshit
even 267@wheels would be at a big push on standard injectors!
Old Mar 18, 2008 | 10:35 PM
davy 6457's Avatar
davy 6457
mine made 273 on standard injectors but there was nothin left in them cos she started runnin too lean so only done 1 run. was surprised by it though. set of greens should sort it out
Old Mar 18, 2008 | 10:53 PM
Gordon1's Avatar
Gordon1
Red face
i was thinking the same but did not want to say
Old Mar 18, 2008 | 10:56 PM
Jasesapphy's Avatar
Jasesapphy
Gunship is how its mapped, so ca be on yellows, greens, t3 or T34.
Basically he does a masssssiivveee boost spike and tails it off as it climbs, so you may very well hit 32 psi of boost in midrange, but tail off to 17-18psi at limiter.
People assume gunship is yellows on T3 but i spoke to Carl about this and its more the way its mapped
Old Mar 19, 2008 | 07:07 AM
KSA-Cossie's Avatar
KSA-Cossie
Thats what i thought.
Old Mar 19, 2008 | 01:18 PM
G2RSR's Avatar
G2RSR
Bodybuilding
100% correctomundo
im not on standard injectors
Old Mar 19, 2008 | 03:26 PM
Twellsie's Avatar
Twellsie
100% correctomundo
200% correctomundo, i too, am not on standard injectors
AJC
Oct 1, 2015 06:47 PM
Mikersturbo
Sep 27, 2015 07:43 PM
