splitters..
Old Mar 17, 2008 | 10:06 AM
R5FORD's Avatar
R5FORD
Default splitters..
hi i had a splitter from moose130 off here..however i tried to put the splitter on with the bumper of the car..and it seems like its about 1/2 inch to short.
when fitting isit best to fit it with the bumper on the car?
cheers..
Old Mar 17, 2008 | 10:07 AM
Ryan's Avatar
Ryan
off the car is much much easier.
Old Mar 17, 2008 | 10:09 AM
R5FORD's Avatar
R5FORD
are they ment to be 1/2 inch to short ?
and do i start from one side and work across? and im using silicon to put it on.
Old Mar 17, 2008 | 10:12 AM
Ryan's Avatar
Ryan
you probably need to pull the bumper closer to the splitter mate.
Old Mar 17, 2008 | 11:29 AM
Twellsie's Avatar
Twellsie
alot easier off the car, clamp it in the middle and work out, adjusting it to suit as you go
Old Mar 17, 2008 | 11:42 AM
Ridgey's Avatar
Ridgey
They are fiddly and very tight to fit. But do go on and look very nice.
I did end up driling mine near the ends and using cable ties to fit, cos i'm lazy.
Old Mar 17, 2008 | 11:45 AM
R5FORD's Avatar
R5FORD
you lazy bugger
R5FORD's Avatar
R5FORD
il try from the middle then..cheers guys.
Old Mar 18, 2008 | 11:46 AM
R5FORD's Avatar
R5FORD
isit best to pop rivet or use silicon? i nearly had the splitter lined up today and then i got pissed of and left it.. try again on thursday
Old Mar 18, 2008 | 11:51 AM
Ima Racing's Avatar
Ima Racing
..i put mine on in situ...a very tight fit and fustrating but will go on
Old Mar 18, 2008 | 11:59 AM
R5FORD's Avatar
R5FORD
yh its very tite indeed. when i get the one side lined up and try doing the other side it seems like the splitter is bending out of shape. and i dont want to force it to much in case it breaks.
Old Mar 18, 2008 | 09:19 PM
CosKev3's Avatar
CosKev3
Neither
Silicone won't be strong enough,you will need to use Tecflex or some other brand of seam sealer/car body bonding stuff.
Don't use pop rivets,the splitter is fibreglass and the shock from the rivet gun will crack it all to shit I would think.
I used small stainless allen bolts and lock nuts and washers on mine
I gave up trying to fit my Moose one and sold it,bought a gen RS500 one that had been chopped down to fIt a Saph,much better IMO.
Rouse ones look like snow ploughs IMO!!!!
Old Mar 19, 2008 | 08:09 AM
R5FORD's Avatar
R5FORD
im going to try again i dont want to get another one.. i just got the ne from moose all painted lol
Old Mar 19, 2008 | 08:25 AM
Twellsie's Avatar
Twellsie
clamp in as many places as possible, drill a series of holes along the length and use some small sellf taping screws
Old Mar 19, 2008 | 08:35 AM
Ryan's Avatar
Ryan
my carbon one was a perfect fit, but the bumper perfectly flat aswell, as they sligthly missshaped over time, being plastic.
i used large rivets on mine and didnt have a problem.
Old Mar 19, 2008 | 09:34 AM
R5FORD's Avatar
R5FORD
yh we got the carbon one on the rs500 to fit perfectly. but this one is pissing me off do i clamp at the back ? or do i clamp across the splitter and rear of the bumper so the clamp pulls the splitter and bumper together?
Old Mar 19, 2008 | 09:58 AM
Ryan's Avatar
Ryan
i started at the end at worked in, i.e riveted it to the side of the bumper, then pulled the bumper hard up agaisnt the splitter the whole way round.
Old Mar 19, 2008 | 10:18 AM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Nice!! Where would i get one like this, to fit a saff?
Old Mar 19, 2008 | 10:21 AM
R5FORD's Avatar
R5FORD
dam peice of shit wont go on
Old Mar 19, 2008 | 10:22 AM
Ryan's Avatar
Ryan
big wull,the place where i got this made dont do the saph ones sorry.
Old Mar 19, 2008 | 11:07 AM
RS_Gav's Avatar
RS_Gav
Where did you get the 500 splitter for the old mans car? Im still after one myself.
Good luck with yours but mate!!
Old Mar 19, 2008 | 11:10 AM
R5FORD's Avatar
R5FORD
mike rainird.
Old Mar 19, 2008 | 11:40 AM
Ridgey's Avatar
Ridgey
I think when i fitted mine i started in the middle, what i mean is found the middle of the splitter and the middle of the bumper and fixed it, NUT and BOLT.
Then worked from there with clamps doing one side at a time, this means you don't end up short or long at the finishing end.
Must admit and extra half inch length wouldn't go a miss to aid fitting them.
Another pair of hands would also be handy.
Old Mar 19, 2008 | 12:12 PM
xr4x4rs's Avatar
xr4x4rs
is your bumper straight or has it sagged at the bottom like most?
as these are a very tight fit, mine was a pain and my bumper is completely straight
but i got there in the end, easier with the bumper off
and you should of done it before having it painted as then the holes are already in the bumper ready for fitting
i just used self tappers in mine and is one very well
i can get pics if you like as the bumper is off the car
Old Mar 19, 2008 | 12:28 PM
R5FORD's Avatar
R5FORD
yh if you could get some pics mate.. how did you put yours on?
i didnt have the bumper painted. just the splitter.
Old Mar 19, 2008 | 01:47 PM
xr4x4rs's Avatar
xr4x4rs
ill go get a pic now
i fitted mine with a load of clamps to get it lined up i had to pull teh bumper to the splitter one side drill the holes and screw it in, then get the other side to fit and do the same then worked on the middle
all before it was painted as you will damage the paint i think if you have already had it painted
ill get a pic up to show you it fitted
Old Mar 19, 2008 | 02:04 PM
c9sse's Avatar
c9sse
is this for your saff or the 500, as a saffy is smaller splitter than the 500 have they sent you the right one.
Old Mar 19, 2008 | 03:14 PM
xr4x4rs's Avatar
xr4x4rs
photobuckte is playing up and wont upload the pics as soon as it does ill post them for you
this is on the saf isnt it
Old Mar 19, 2008 | 10:07 PM
R5FORD's Avatar
R5FORD
yh for the saph mate.
Old Mar 20, 2008 | 01:14 AM
xr4x4rs's Avatar
xr4x4rs
well it let me upload 3 of the pcis lol
not much to look at reayy but this is what mines held in plave with, screws have gone a bit rusty but hey its underneath the car lol
just normal self tappers, havnt ripped it off yet
pic of it on the car
Old Mar 20, 2008 | 02:54 AM
R5FORD's Avatar
R5FORD
iv finaly got it on
but on the edges iv used silicone. and if that dosent hole im going to pre drill a hole and then pop rivit.
on the edge at the bottom i havent pushed the bumper and splitter together. it fits very tite against the bumper so looks very good.
its alot lot easier with the bumper on the car
Old Mar 20, 2008 | 07:05 AM
KSA-Cossie's Avatar
KSA-Cossie
Thats what i did.
Old Mar 20, 2008 | 07:07 AM
KSA-Cossie's Avatar
KSA-Cossie
Self tappers will be better m8.
Old Mar 20, 2008 | 07:10 AM
Moose 130's Avatar
Moose 130
told you it'd go on!
now, just stay away from curbs and you won't have to do it again!
let me know how you get on with teh windscreen hunt though.
Many thanks
Old Mar 20, 2008 | 08:08 AM
R5FORD's Avatar
R5FORD
iv spoken to my contact. got one if you want it. il find out the best price if your after it.
yh it was alot easier with the bumper on the car and look great in gloss black
Old Mar 20, 2008 | 08:09 AM
R5FORD's Avatar
R5FORD
and im more woried about the stupid sie speed bumps out here that the kirbs cry::
