T4 chip
Mar 16, 2008 | 10:42 PM
T4 chip
Chip specced for 7.5:1 comp, T4, greys, BD10 inlet cam and polished ports in the head.
Would it be ok to run on a car with same standard comp and without BD10 cam and polished ports?
Mar 16, 2008 | 10:48 PM
no it will need a remap or a correct chip any thing that increase performance will need a tweek to the map if its dosnt need a tweek then ther was no gain to be had
Mar 16, 2008 | 10:54 PM
it was low comp not standard
Mar 16, 2008 | 10:56 PM
I always thought you were standard comp. Hang on, an edit is looming. ^^^^ there
Mar 16, 2008 | 10:57 PM
Mar 16, 2008 | 10:58 PM
The odds are stacked against it now. Hmmm, might change this thread to "where can I get a chip...."
Mar 16, 2008 | 11:00 PM
sounds like a good idea
or just increase your spec to match ours, then buy it, and get it mapped, job done..... after a bit of cash
Mar 16, 2008 | 11:02 PM
If the chip is done correctly then it will have substantially too much advance for a Std Comp YB and will destroy it.
Mar 16, 2008 | 11:22 PM
Quote:
Originally Posted by
Stu @ M Developments
Initially I thought the spec was the same bar inlet cam and polished ports. Like you say the advance will destroy my engine. Bugger.
You have PM Stu.
Mar 18, 2008 | 12:16 AM
Dicko&Sarah
Dicko&Sarah
bottom end was standard, but it had light head work before t4 and a bd10 inlet cam
Sarah
make your mind up!!
Mar 18, 2008 | 08:13 AM
BigErn
i know, i forgot that it had the low comp after the engine went
first time round
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
