help fuses melting fiesta rs turbo
Guest
Posts: n/a
hi,just wondering if anyones had this problem and can advise me,got a fiesta rs,done a headgasket,water pump,cambelt,fan switch,thermostat etc etc all runs mint but yesterday the 30a fuse for the fan(second in from the top left),every time the fan kicked in the circuit got so hot the green cover kept completely melting off the fuse in under 1 minute,went through 5 fuses just to get me home.ive had a new fan switch,the fan looks ok in terms of it works and when off spins by hand with minamel resistance.also the fan apperantly runs through the front foglight relay which i changed and they work when the fans on,just the relay cant be pushed in all the way to the fuse box or that circuit cuts out.why is this circuit getting so hot and not popping the actual fuse,help help!!!
Let me know what the problem is coz mine does it with the lights! i can have full beam or sidelights but not dipped! I have gone thru 100's of headlight relays, fuses etc and they are ok for about 30 mins then fcukt I have given up trying to find a solution other than trying to get hold of an interior wiring loom! Sorry not much help i no but you aint the only one!!!
paceo
Feb 3, 2016 10:31 AM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
