NOS!?
Old Oct 20, 2004 | 09:29 AM
B19-TRB's Avatar
B19-TRB
Default NOS!?
Does runnin NOS on a turbo'd car put extra strain on the turbo itself!? t34
How much NOS is safe to run on a standard 200 block, head(bd10)!?
Old Oct 20, 2004 | 09:38 AM
DanS's Avatar
DanS
Old Oct 20, 2004 | 09:43 AM
B19-TRB's Avatar
B19-TRB
ooowww flames!
Old Oct 20, 2004 | 10:38 AM
Rene's Avatar
Rene
when i was on the phone last year when i was rebuilding me engine he told me i should forget nos and build just a proper engine!
Old Oct 20, 2004 | 10:49 AM
RS500/364's Avatar
RS500/364
Is that MAD who used it on the 200+
Old Oct 20, 2004 | 11:30 AM
Jim Galbally's Avatar
Jim Galbally
no
as for ammount, most peoppe seem to stick with 100/150 hp jets (which will probably give a 150-200bhp increase)
dunno anyone running <100 on a cossie...
Old Oct 20, 2004 | 12:10 PM
alistair's Avatar
alistair
nitrous on a turbo car can/should act as a charge cooler... Not just more power from the nitrous but more power can be wrung out of the turbo too. Never done it myself but its well documented.
Only reason cars "blow up" with nitrous is bad installation/maintenance or use of some poor quality components and/or pushing the motor beyond the limits of what it can take - which would be true what ever method of tuning you employ. Try and run 50 PSI boost on a 125K mile bone-stock 1.3 Endura bottom end isn't going to last very well, but people have got over the fear of turbos which came from bad turbo installs in the 70s and early 80s which did blow motors up. Same with nitrous. Technology is moving on.
Some kits are more appropriate to small capacity engines common in UK / Europe than others. What works well on a 7.5 litre Chevy isn't going to bolt right up to a 1.6 CVH turbo...
How much gas you can run depends on may factors, but you can start small and work up, the jets are cheap enough. Your ignition system will probably decline to light it all off before you get to the point it does damage (assuming a properly built turbo motor).
turbotrev
39
Apr 17, 2016 09:03 PM
28
Sep 8, 2015 07:10 PM
The Enigma
Sep 8, 2015 07:03 PM
155lee
14
Aug 22, 2015 12:15 PM
