Where does the ECU go?
Chaps im just putting my dash in and just wondering where do i mount the ECU??
also ive got loads of fuses (diff colours) just wondering where they go...
also just wondering does anything mount near the passenger/driver side footwell?
anyhelp would be great! ta.
ive got a 2wd coss btw.
Raz
Raz
cheers
any idea about the fuses??
and also the ECU has a black connector but ive got a large green connector as well that plugs into another unit that I have..any idea where that locates/attaches to?
If memory serves me right(?) the green one is the ABS ecu, this is on a bracket that mounts directly above the engine ecu, and has a lower part of it into which the engine ecu secures.
There are various relays/fuses on the main engine loom near the cu that mount above your feet, passenger side.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
