No Dash lights ........
Old Mar 14, 2008 | 12:53 PM
steano's Avatar
steano
Default No Dash lights ........
All my instruments work but they dont light up green any more
Any ideas ?
Old Mar 14, 2008 | 01:55 PM
iansoutham's Avatar
iansoutham
OCD Victim
Check your back lights with the sidelights turned on. Bet they are not on.
If this is the case, then you need to replace the indicator / light stalk as the internals have fried themselves (natural causes). The dashlights are on the same circuit.
Things not working will be:
drivers lights-on door buzzer
rear side lights
numberplate lamp
front sidelights (but headlights will work)
dashlights / heater controls lights / cigarette lighter light
This is a common problem on all 1991 onwards Escorts.
1027172 is the finis number from Ford (they are about £70 though).
Old Mar 14, 2008 | 01:59 PM
kjc300's Avatar
kjc300
and if its not that, it'll be the inverter in the back of the clocks
Old Mar 14, 2008 | 02:28 PM
iansoutham's Avatar
iansoutham
OCD Victim
That would affect everything except the lights.
If it is not that (the switch), then it is a fusebox issue.
Old Mar 14, 2008 | 04:53 PM
MarkN's Avatar
MarkN
If its the inverter then none of the gauges will light up - the rest of the dash - heater and switches will still work.
You may want to check the dash dimmer first - make sure that its turned up and that the plug hasn't fallen off the back.
Old Apr 9, 2011 | 05:00 PM
PaulScorpio's Avatar
PaulScorpio
rear side lights
numberplate lamp
I have this problem with my Ford Focus 99 model. However I have replaced the main light switch on the dash as my lights are controled by a switch on the dash and not on a stalk like described above, I am still having the same problem after replacing the light switch.
Sorry for posting this in the wrong forum but this is the only reference to my problem I could find via search.
Any help would be appreciated.
Many Thanks
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
imnoteasy
Sep 7, 2015 09:26 PM
