How difficult is it to change the Valve Stem Oil Seals??
Old Mar 12, 2008 | 10:11 PM
MJ_RST's Avatar
MJ_RST
Default How difficult is it to change the Valve Stem Oil Seals??
As title, needing to replace the Valve Stem Oil seals on my zetec engine, suspect oil leaking past, how difficult are they to replace?? What all is involved?? any pix would be much appreciated also
cheers
Old Mar 13, 2008 | 07:43 AM
I could be wrong but im pretty sure it will be cylinder head off to do the seals.
Old Mar 13, 2008 | 11:41 AM
rsnissan's Avatar
rsnissan
you use the roap trick if you want to keep the head on
Old Mar 13, 2008 | 06:34 PM
MJ_RST's Avatar
MJ_RST
Rope trick??
are there any specific tools needed??
Old Mar 13, 2008 | 07:40 PM
JonathanJ's Avatar
JonathanJ
Ford say you can do this without taking head off , using special tools !!! but thay are not that special , they say use compressor to feed air into cylinder at bdc , and the compress valve spring using a couple of special tools , do you know anybody in a ford workshop , will see if I can scan the workshop manual and send if you like so you can see ,I have access to it from home let me know .
You could try doing it at tdc and make yourself a lever bar up to compress springs with a cut down tube .
Old Mar 13, 2008 | 07:43 PM
JonathanJ's Avatar
JonathanJ
BTW rope trick is to take plug out then feed rope into cylinder then slowly bring piston to tdc trapping rope inbetween valves and piston then you can compress valve collet with tool as required
Old Mar 13, 2008 | 07:46 PM
It's doable but fiddly, as they are a bit deep on zetec heads.
I would use the NYLON rope trick, rather than compressed air, knowing my luck the compressor would stop working!!
Old Mar 13, 2008 | 07:49 PM
JonathanJ's Avatar
JonathanJ
I agree tabetha . I am also great believer in " mechanical " locking not compressed locking , unless you have a very reliable way to lock flywheel with piston at tdc so if compressor or pipe failed the valve cannot drop into oblivion
Old Mar 13, 2008 | 07:58 PM
MJ_RST's Avatar
MJ_RST
That would be great if you could send me that mate cheers
I have to replcae the head gasket anyway, as its gone, so i wont need to go down the compressed route.
Old Mar 13, 2008 | 09:02 PM
JonathanJ's Avatar
JonathanJ
what address would you like these sending to ?
Old Mar 13, 2008 | 09:48 PM
MJ_RST's Avatar
MJ_RST
PM for ya mate
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
Danielbetty
Aug 28, 2015 08:01 PM
cameron2
Aug 25, 2015 07:18 AM
st220kyle
16
Aug 14, 2015 06:13 AM
