cosworth 4x4 pistons with 2wd head compression ratio
Old Mar 12, 2008 | 09:58 PM
garyrs's Avatar
garyrs
Default cosworth 4x4 pistons with 2wd head compression ratio
hi peeps , i am just wondering if any of you can help me with the any of the following combination of pistons all to be standard items , anny help would be very helpfull
standard 2wd cosworth
205 block -4x4 pistons-2wd head
the cc of a 2wd head
the cc of a 4x4 head
thanks gary
Old Mar 13, 2008 | 03:20 AM
cozmeister's Avatar
cozmeister
More boost Igor!
cubic capacity of a standard YB (all flavours) is 1993cc.
The 4x4 pistons are a direct replacement for the 2wd ones, and shouldn't make a difference to the cubic capacity.
Standard compression ratio is 8.0:1.
Old Mar 13, 2008 | 04:49 PM
garyrs's Avatar
garyrs
thnks for the reply cozmeister, i should of made the question clearer
i am looking for the compresion ratio of a 205 block with 4x4 pistons and a 2wd head and a group a gasket , im prty sure the 4x4 pistons have a bigger dish so should lower the compresion ration when used with a 2wd head ,
as for the head question i meant the cc of the combustion chamber in the head ,
thanks gary
Old Mar 14, 2008 | 12:49 PM
silky16v's Avatar
silky16v
Get on That!
thanks gary
it would in theory drop the comp to 7.8:1
Old Mar 14, 2008 | 01:58 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
100% correct (given that the head is not machined to fuck ).
Old Mar 14, 2008 | 02:18 PM
garyrs's Avatar
garyrs
thanks silky and mike for comfiming it , the head that went on was measured at 138.6 ,and was a group a gasket used ,im not sure if these are the same compressed thickness as the orignal one ,
can any one help with the cc of the heads
thanks again
Old Mar 17, 2008 | 06:49 PM
PGT's Avatar
PGT
a 2wd head i measured recently was 53cc and irrc it was 138.9mm thick.
Old Mar 17, 2008 | 06:52 PM
garyrs's Avatar
garyrs
Thumbs up
lovely ,thank you very much
Old Mar 17, 2008 | 06:56 PM
PGT's Avatar
PGT
dont know if it helps but i reckon old valves (with low margin) will add another 4 - 5 cc and polished chamber prob another 1 or 2
Old Mar 18, 2008 | 06:06 PM
garyrs's Avatar
garyrs
didnt think of that , think i will measure it me self so i no for sure , thanks
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
