Just upgraded the spec on my saph
Old Mar 11, 2008 | 09:06 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Just upgraded the spec on my saph
Went from t34.48 and greens to t34.63 and siemens blacks with new chip from MSD and it fookin flies now so smooth and yet so powerfull,well done and big thanks to simon at sitech racing.
Old Mar 11, 2008 | 09:10 PM
rapidcossie's Avatar
rapidcossie
Should have done a power test before and after Kev to really see the differences.
Can remember it went well before so like you say it must be a flyer now
Old Mar 11, 2008 | 09:12 PM
KSA-Cossie's Avatar
KSA-Cossie
Ws 358 at 26 psi and 373 at 28 euan,that was on dasteks rollers.
Old Mar 11, 2008 | 09:13 PM
STUCOS's Avatar
STUCOS
Did you see brian's car there kev,
cheeRS stu
rapidcossie
get it back to the same rollers and report on the results
Old Mar 11, 2008 | 09:17 PM
KSA-Cossie's Avatar
KSA-Cossie
cheeRS stu
Caught a wee glimpse of it under the cover and pinched his wheels.
Old Mar 11, 2008 | 09:18 PM
KSA-Cossie's Avatar
KSA-Cossie
My m8's getting his subaru remapped so gonna go back eith him deffo m8.
Old Mar 11, 2008 | 09:19 PM
STUCOS's Avatar
STUCOS
mmmmmmmm think it,s going to go booooooooooooooooom
cheeRS stu
ps when you coming to do my lights
Old Mar 11, 2008 | 09:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Goes like fuck not boom. Speak to you about lights on sat night,you can bribe me wi beer.
Old Mar 11, 2008 | 10:38 PM
Csm's Avatar
Csm
I await the next big post Kev ................................
My bottom ends knocking its tits off
Sounds like a belter now tho
Old Mar 11, 2008 | 10:44 PM
rapidcossie
Kev...has Si had the det cans/AFR gauge on it?
Should be cool if he has checked it so dont worry!
Old Mar 11, 2008 | 10:45 PM
mechanic28's Avatar
mechanic28
what c/r you on mate?your a 205/200?just interested as i might what to go the same route with a .63 from my .55
Old Mar 11, 2008 | 10:47 PM
col cos1's Avatar
col cos1
good stuff mate
Old Mar 11, 2008 | 11:06 PM
toff's Avatar
toff
Sounds good Kev.
Am just waiting on a few more bits before a go down the same road, but with the T4
Old Mar 11, 2008 | 11:20 PM
silky16v's Avatar
silky16v
Get on That!
GEARBOX, Gearbox, Gearbox won't be long before it shits it, if you drive it real hard
Old Mar 11, 2008 | 11:36 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
this is where i want to head with my one mate well done must go well now
Old Mar 12, 2008 | 01:47 AM
R5FORD's Avatar
R5FORD
i got my car tuned up last week. hitting 405bhp on a .48 housing blacks. msd closed loop chip. peaking 31psi and hlding 27psi.
Old Mar 12, 2008 | 06:11 AM
I'm hitting 330bhp on 18/19psi, as modded head.
torque is 150lbft@1500rpm, 330lbft@2200rpm and still 330lbft at 6500rpm, on a .48.
Old Mar 12, 2008 | 07:05 AM
KSA-Cossie's Avatar
KSA-Cossie
He sure did m8 .
Old Mar 12, 2008 | 07:06 AM
KSA-Cossie's Avatar
KSA-Cossie
Standard 200 block m8,not much laggier than the .48 imo but holds the power right to the limiter now.
KSA-Cossie's Avatar
KSA-Cossie
Get it done tony you'll love it m8.
Old Mar 12, 2008 | 07:08 AM
KSA-Cossie's Avatar
KSA-Cossie
Nice power on a .48
Old Mar 12, 2008 | 07:38 AM
R5FORD's Avatar
R5FORD
Nice power on a .48
its got the .48 housing but its a complete diff turbo. goes nice tho
Old Mar 12, 2008 | 10:29 AM
NEIL A's Avatar
NEIL A
So you will be needing an uprated box and diff plate then Kev
Old Mar 12, 2008 | 10:46 AM
Dan's Avatar
Dan
Sounds wicked mate! Genuinely, what do you think of the lag of a .63 compared to that of the old .48?
Cant wait for the results on the same rollers!? What's the time scale?
Old Mar 12, 2008 | 10:48 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
sounds ace kev. i'd love a spin in your car at some point. Love it!
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Nice work. Do you find the .63 laggy compared to the .48. I dont but people still dont beleive me
Old Mar 12, 2008 | 11:04 AM
rog's Avatar
rog
Sounds like a good move, is this an off the shelf chip or did you take it to MSD??
Old Mar 12, 2008 | 11:05 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
off the shelf rog.
considering it myself.
Old Mar 12, 2008 | 11:07 AM
rog's Avatar
rog
I was going to go greys and T34/0.63 once it's all safely run in etc... but this looks like a more "up to date" option
Old Mar 12, 2008 | 11:12 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i was on same thinking as its the next step.
however the better way is a set of siemens "black" injectors which flow better and a chip from MSD
Old Mar 12, 2008 | 11:14 AM
Dan's Avatar
Dan
IIRC 55lb 'blacks' are more than man enough for this job from Stu!
Old Mar 12, 2008 | 11:15 AM
Gary F's Avatar
Gary F
Does anyone know how a T4 and a T34/.63 compare lag wise?
rog's Avatar
rog
I think you could be correct.... I need to get it all legal first and fix the rear bodywork (bumper and roll arches, possibly front ones too) Then i can mess around with the rest of the spec.
Old Mar 12, 2008 | 11:21 AM
Dan's Avatar
Dan
Quite a jump and a noticeable difference as far as I know Gary!
Guess it really is dependent on spec and engine etc aswell, i'm sure someone who has had first hand experience of both turbo's will be on here somewhere and can comment
Old Mar 12, 2008 | 11:26 AM
R5FORD's Avatar
R5FORD
seems alot laggier imo
Old Mar 12, 2008 | 11:31 AM
Sticky.'s Avatar
Sticky.
Nice one Kev...
It's a great conversion & had it on mine for a while now.
Old Mar 12, 2008 | 12:57 PM
rapidcossie
depends what engine they are on.
My T4 is comparable with a t34/63
Old Mar 12, 2008 | 01:02 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Thought you was on a .55 ?
Old Mar 12, 2008 | 01:15 PM
CossieRich's Avatar
CossieRich
Well you thought wrong then see my sig. changed to .63
