4x4 shock in 2wd hub?? anyone got ideas?
Rubber Rhino Crew
I have a very nice set of leda remote res coilovers that are set up to run with the conncentric top mounts I have already.
I have since decided to go to 2wd in stead of 4wd but really dont want to get rid of the shocks as similar would cost more money I dont have at the minute.
My main question is can I have the 2wd hubs machined out to accept the 4x4 shock? Has anyone actually ever done this? I have heard that there is a different material arround the area i'd need to machine..any ideas?
Dan
Dan
Rubber Rhino Crew
well I do have a 4x4 front end I could put on instead of the 2wd front end.......Although I did hear from someone that it doesnt steer right when you do it this way..major bump steer or something??? I dunno...
how does yours steer will?? notice anything different to a normal 2wd car?
Dan
Dan
