ap brakes
Old Mar 11, 2008 | 07:10 PM
gus's Avatar
gus
Default ap brakes
i have a set of 330mm ap four pots (think they are cp5200 not sure)
will these callipers fit ok on 315mm discs
would my bells be ok, just need the smaller discs and bracket?
thanks
gus
Old Mar 11, 2008 | 07:16 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
thanks
gus
As long as you are just down sizing on the same car then all you will need is a pair of 315mm discs with the same pcd as the original 330's and about 7.5mm machined off the bracket.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
