A drop in CR
Old Mar 11, 2008 | 01:29 PM
sas's Avatar
sas
should be good!
Default A drop in CR
I have just had to drop my CR from 9.1:1 down to 7.9:1 due to headgasket supply and deeper valve pockets in the pistons.
So driving it feels slow! gone has the super quick response, and it now doesnt pull smoothly, there are steps in the power band, and it doesnt wheelspin in 6th anymore.
However it is still on its high CR ignition map! will be remapping which will remove the steps.
Boost has fell by 1psi and EGT has fell 50 deg C.
No other changes to the car.
Simon.
Old Mar 11, 2008 | 01:50 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Report back when the ignition as been put back in, along with the more boost that you can now run .
You should find an even greater reduction in EGTs .
Old Mar 11, 2008 | 04:25 PM
sas's Avatar
sas
should be good!
Will do.
Old boost was 21psi.
Tried to up boost on 9.1 CR but ignition system could not produce enugh power.
S.
Old Mar 11, 2008 | 05:11 PM
rapidcossie's Avatar
rapidcossie
Si...if i told you what my CR was you would not believe me.
Low comp or in my case VERY low comp does NOT have to make a bad driving car.
Have a play about and see what I mean!
Old Mar 11, 2008 | 06:03 PM
KSA-Cossie's Avatar
KSA-Cossie
Oi get on with making my saph faster !!!!!!
Old Mar 11, 2008 | 06:07 PM
GARETH T's Avatar
GARETH T
Originally Posted by sas
Will do.
S.
wouldnt increasing the power of your ignition system be a good place to start?
Old Mar 11, 2008 | 06:25 PM
Rick's Avatar
Rick
ive gone from 7.3 to 8.4, and it's no more responsive at all - lots of ignition had to come out. Be interesting to see what yours is like with the added lead.
Old Mar 12, 2008 | 10:47 PM
sas's Avatar
sas
should be good!
Did a bit of mapping tonight. Only ignition.
Added 5 deg of advance across all load and rpms ranges.
Result almost removed all steps in power but saw a decrease of 40 deg C in EGT.
Had to stop as snowing again.
S.
Old Mar 12, 2008 | 10:50 PM
col cos1's Avatar
col cos1
my compression is 6.9.0 and pretty sluggish low down the revs,but youll be able to play with that when mapping si eh???????/lol
Old Mar 12, 2008 | 10:52 PM
rapidcossie
get the boost whacked up Si!
Old Mar 13, 2008 | 08:45 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Are you in the 6?
Old Mar 13, 2008 | 09:51 AM
Mike Rainbird
Caraholic
S.
Who would have thought it?
Given the large drop in c/r, I would have thought that it would take some more ignition, but I would put some boost into it first (the amount you want to run) and then see what you can get away with ignition wise .
Old Mar 13, 2008 | 09:54 AM
CossieRich's Avatar
CossieRich
The man speaks the truth You can become a true boost junkie
Old Mar 13, 2008 | 09:56 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Originally Posted by CossieRich
Are you in the 6?
likes he'd tell you
although col revealed his above
my rst engine from ava was LOW comp too
Old Mar 13, 2008 | 09:57 AM
CossieRich's Avatar
CossieRich
Originally Posted by Lambchop
likes he'd tell you
Not to worry Chops. i'll just ask Mark Shead
Old Mar 13, 2008 | 10:43 AM
sas's Avatar
sas
should be good!
Agreed it will take more ignition.
However I am gaining info on ign, EGT, CR at the moment when I finish then will do more maping with more boost.
S.
Old Mar 13, 2008 | 12:43 PM
rapidcossie
Hey rich...its lower than col's which is 6.9, thats all i will say.
Mark doesnt know the exact comp ratio either.
Old Mar 13, 2008 | 12:46 PM
rapidcossie
S.
Si wish you could mess around with all this on the rollers as you would see what happens to the power when you make these changes.
Its always very interesting!
Old Mar 13, 2008 | 12:50 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The comp ratio is in the map on autronic, so he will do if he has ever helped with your mapping.
Not that it matters
MikeR, nice accurate info
Old Mar 13, 2008 | 05:43 PM
rapidcossie
If its in the map then he does know it chip....
My mistake
Old Mar 13, 2008 | 06:31 PM
col cos1's Avatar
col cos1
euan whats the big secret with it mate?
Old Mar 14, 2008 | 08:02 AM
CossieRich's Avatar
CossieRich
Low is good in my book
Old Mar 14, 2008 | 12:32 PM
rapidcossie
not a secret col...just cant be bothered with the hassle of posting it as people will only say its shite!
Old Mar 14, 2008 | 12:42 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Is it 2:1?
Old Mar 14, 2008 | 12:46 PM
Dan's Avatar
Dan
Originally Posted by Stavros
Is it 2:1?
Sorry but
Old Mar 14, 2008 | 12:47 PM
dumped's Avatar
dumped
Old Mar 14, 2008 | 12:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Awesome, that was gonna be my 2nd guess
Old Mar 14, 2008 | 12:57 PM
lead_foot's Avatar
lead_foot
is awesome
Got to be around 1:5 for proper low comp.
Old Mar 14, 2008 | 01:46 PM
CossieRich's Avatar
CossieRich
How you could think anyone would say its shite given what you car has achieved is beyond me lol. But still, it doesnt really matter, i was just interested to know
Old Mar 14, 2008 | 01:48 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i reckon its 6.3:1
fuck what people say about high comp enignes, they all blow up lol
mine is 7.77:1 btw, wanted lower but not enough meat on the pistons to be safe with mega boost to take any more off
Old Mar 14, 2008 | 02:20 PM
Luca's Avatar
Luca
Lukesville
Dan at a figure of say 400hp what pressure you planning on running and when you up Pro Alloy i have to go there shortly too.
Old Mar 14, 2008 | 03:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
all of it lol
dunno, whatever the engine can take.
my boost gauge will only go up to 30psi tho lol
ill next be at pro on the 29th to collect the car, and take it to hayward and scott, provided i have sorted the manifold by then, else it will be going to reyland lol
Old Mar 14, 2008 | 04:21 PM
Taylor's Avatar
Taylor
Fuck what some of the wahoo's on here say Euan,at the end of the day check the stats in your sig and that says it all!
Will ge you a buzz over the weekend by the way mate,could be needing a wee favour regarding heating! By the way was reading the Crail post and if you still need a lift to Macdonlds in the morning then let us know mate
Old Mar 14, 2008 | 05:26 PM
rapidcossie
cheers Keith!
See you at mcdonalds
Old Mar 14, 2008 | 05:28 PM
rapidcossie
Rich, Rod has already informed me that we are stuck in the 80's fro running low comp and using T4's so you can see what I mean.
Doesnt matter if the car runs 188 mph in the wet with a fucked headgasket or not its not in fashion so it will never work!
Old Mar 14, 2008 | 05:41 PM
dumped's Avatar
dumped
Yip euan filling up at the petrol station must be slightly less annoying than paying for rocket fuel, filling and checking your nos and nitrogen and then having to check the water/methanol mix in your water injection.
Old Mar 14, 2008 | 05:44 PM
col cos1's Avatar
col cos1
lol
Old Mar 14, 2008 | 05:47 PM
Stu @ M Developments's Avatar
PassionFords Creator
Such a complex subject...
Old Mar 14, 2008 | 05:48 PM
rapidcossie
i could prob put normal 95 RON in it and it would still be fine
Old Mar 14, 2008 | 05:59 PM
col cos1's Avatar
col cos1
how long until you get the car back euan?
