4x4 Saph Brake Pipes, original Oem
does anyone know if you can still get these brakes pipes pre made up from the ford dealership i'm needing the rear pipes on the trailing arms and the pipe that run from front to rear and then the 2 from the T-piece
If you put on HEAT SHRINK, DARK GREEN, then heat it, it will shrink to size and if care is taken not only will it look identical, but will not rot or anything like the oe stuff.
Just put the heat shrink on before doing the last union.
track.focus'd
Aug 12, 2015 05:53 PM
