FilterMAG
The greatest amount of wear in engines is caused by contaminants that are not stopped by oil filters alone.Of all contamination found in oil,none does more damage than steel(iron) particles,created by normal engine wear.Typical automotive engine oil filters are not effective in trapping the steel particles.Steel particles can cut through oil filter media and are continually circulated through the engine.
Installed on a typical oil filter,FilterMAG stops and retains contaminants of all sizes even smaller than 2 microns.FilterMAG does this with its patented design of focusing magnetic energy into an oil filter very much like a laser focuses light.Depending on filter size and usage,FilterMAG focuses from 110 to over 1,000 pounds of magnetic energy to the filter.
Filter Diameter
SS250 63-70mm £39.95
SS300 70-87mm £47.95
SS365 87-99mm £58.95
RA300 70-87mm £54.95
RA365 86-108mm £119.95
RA450 108-140mm £169.95
Prices include VAT
TRADE ENQURIES WELCOME
Filter Diameter
Prices include VAT
