Autronic smc
Old Mar 10, 2008 | 09:14 PM
rs50087's Avatar
rs50087
Default Autronic smc
I want to use the original crankpully on the cossie engine and there are 4 "taps" on it,but when im going to use autronic im only going to need 2 of the "taps" does anyone know which of the 2 I have to remove?
Old Mar 16, 2008 | 02:45 PM
cosworth86's Avatar
cosworth86
Time the engine as usual, then take away the tooth on tdc1 and the tooth on the tdc sensor (180degrees from the tdc 1 tooth)
15
Oct 7, 2015 03:43 PM
extra15
28
Nov 8, 2005 10:05 PM
mtcossie
Ford Escort RS Cosworth
Aug 27, 2005 01:52 PM
nor_cossie
11
Sep 3, 2004 10:39 AM
