Escort Cosworth - My Spec, what next!!!?????
Old Jan 30, 2004 | 10:37 PM
kjc300's Avatar
kjc300
Default Escort Cosworth - My Spec, what next!!!?????
'93 Big turbo Esc Cos
GGR335 chip
standard comp.
T34 .63ar 360 bearing
GpA Fuel Pump
803's
Coopers ringed block
Gen RS500 i/c being fitted by me next weekend!!
All silicon hoses - next weekend too!!
Breather etc.
Mongoose.
Running around 24 psi at the mo. Prob be happy with 400 bhp in the end.
Here is the long list!!
Boost control - adjustable. Air to air/e-boost??
Greys??
Cams?? Not changing pistons so prob bd10's??
Coil pack conv!!?? like the sound of this one!!
Secs S8 ecu!!!!!!!!!!!!!!!!! price?????
Live map??
Ap brakes/big disc conv./mike R rear disc??
Happy with my koni's at the mo(not been on track yet!!)
Hopefully should have about a grand and a half to chuck at my moneypit after I sell my old motor and get out of my overdraft!!!!!
Old Jan 30, 2004 | 11:01 PM
kjc300's Avatar
kjc300
Old Jan 31, 2004 | 09:36 AM
Panza's Avatar
Panza
Old Jan 31, 2004 | 01:38 PM
swerv's Avatar
swerv
greys , air-to-air , live map , lots of boost
oh and the biggest brakes you can fit , you wont regret spending money on the brakes , enjoy
Old Jan 31, 2004 | 01:58 PM
dave cos4x4's Avatar
dave cos4x4
I would say brakes too.
Is fast enough to warrent a decent set of brakes!
Dave.
Old Jan 31, 2004 | 02:09 PM
wighthot's Avatar
wighthot
Yep got to agree with the brakes, bigger the better
oh and big brakes look very
Old Feb 1, 2004 | 08:37 AM
kjc300's Avatar
kjc300
Cheers guys, should be on the lookout after tuesday then. Someone having another look at my mk5 turbo, I reckon he'll have it!!
Old Feb 12, 2004 | 09:03 PM
Hi,
can you give me any info regarding the "Coopers ringed block", mine has the same but I aint got a clue what it is or does!!
Cheers, Nik
Old Feb 12, 2004 | 09:14 PM
kjc300's Avatar
kjc300
Hey Nik,
coopers ringed is basically where each bore has a groove or step machined around it. This then allows a steel 'ring' which I think is about 4mm wide - sort of flat in section, to fit in the groove. This ring actually sits slightly higher than the surface of the block. You need a special gasket to go with these as well, and where the rings are slightly raised exert more pressure on the head gasket, in theory providing a better seal around the bores. I think that's about it. If I have got anything really wrong I'm sure somebody will correct!!
Old Feb 12, 2004 | 09:19 PM
kjc300's Avatar
kjc300
Old Feb 12, 2004 | 09:26 PM
nice one, cheers Kev, mmmmm, very intersting, sounds a better set up than the scooby that I blew the head gasket on!
Ta mate, Nik
Old Feb 12, 2004 | 11:17 PM
PJay's Avatar
PJay
one thing kev forgot to mention is that coopers rings are fooking expensive
Old Feb 14, 2004 | 07:43 PM
Milko's Avatar
Milko
So how much boost can you run on standard pistons?
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
