Different spring rates??
Old Mar 9, 2008 | 07:44 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Different spring rates??
When cleaning some bits for repainting I discovered to see 2 different front springs on my car. 1 Spring has got a colour code 'red red' and the other one has got 'green violet'.
The car has yellow Koni's but I'm not sure if these springs are also from Koni.
Does anyone know the difference between these colour codes or is there not much difference between the ones on my car?
Hope you can help.
Old Mar 10, 2008 | 08:37 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the 4wd cars were supposed to have diffrent spring rates for the driver and passenger side front to allow for the drivers weight as well as the diff etc on that side from the factory
perhaps this is the case with these?
Old Mar 10, 2008 | 01:08 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
That crossed my mind too. But I have a lhd car... so still fit the most strongest spring at the turbo (diff) site??
And as they are black coated these springs arent from KONI. Any ideas what brand they can be??
Old Mar 10, 2008 | 04:59 PM
dojj's Avatar
dojj
test the poundage
make up a rig like this to work out the spring rate and it's easy
just make sure you make it from metal as wood tends to bend a bit more
Old Mar 13, 2008 | 05:35 PM
white4x4cos's Avatar
white4x4cos
Looks like standard springs to me wim.
Have some original springs of my own car somewhere.
Can check if they are the same color coding if you want?
Old Mar 18, 2008 | 08:59 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Hi,
Well the car is lowered and the springs arent cutted. They are also shorter than original ones. Could take the spring of the damper without using special tools to clamp the spring.
Contacted Koni and they told me they have never made black springs. So its from another brand.
Old Mar 18, 2008 | 05:45 PM
white4x4cos
Wim i had a look at original springs that came from my car and they have the same color coding.
So i am pretty sure they are the original springs mate.
Old Mar 19, 2008 | 08:46 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Oeps...
Time for a change then in the future!
Thanks Johan
Old Mar 19, 2008 | 08:58 PM
white4x4cos
got some eibach springs if you want?
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
CrOwSoN15
Sep 24, 2015 01:36 PM
L1AM_RS
Sep 23, 2015 03:27 PM
