escort gti trouble
Old Mar 8, 2008 | 11:52 PM
battygti's Avatar
battygti
gti mad
Default escort gti trouble
i have recently brought a escort gti and have a few problems with it.the first problem is that it is loseing water but the oil has not gone milky white.ive had the cam belt,water pump and the thermostat changed.ive done a compression test and all 4 cylinders are holding 170lbs.the second problem is that when the car is ticking over it sounds like its missing.its had new plugs and leads. any ideas would be very grateful as i am starting to pull my hair out.
Old Mar 11, 2008 | 12:59 AM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
A head gasket can blow in many differant ways, check if the rad hoses are getting hard to sqeeze, if so then it sounds like the gasket is letting water into the combustion chamber hence the miss-fire.
Old Mar 11, 2008 | 07:48 PM
battygti's Avatar
battygti
gti mad
Default gti trouble
thanks for the reply,they do get quite hard when the engine is running.ive just done a compreeion test on the engine and coolant side.the engine is holding 170lbs and the coolant is holding 1.4 bar.ive been advised to do the head gasket anyway.ive had a bit of a stroke of luck as ive just managed to buy a head of a black top mondeo engine that has only done 60k.i have been told that it will fit straight on just changing the parts of my head onto the new one.i'll see how it goes.
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
