Temp gauge reading on Escort Cosworth
Old Mar 6, 2008 | 03:32 PM
JohnP001's Avatar
JohnP001
Default Temp gauge reading on Escort Cosworth
I’ve had my Escort Cosworth for 7 years now, and for all this time when the car gets to operating temperature, the temperature gauge has always shown between the black block and the “M”. In other words towards the bottom of the gauge. A few days ago, the temperature gauge has now started showing between the “O” and “R” of NORM all the time, even when stationery in traffic. I’ve checked the water level, and this hasn’t moved at all.
So the question is; where does your temperature gauge needle sit when running at operating temperature?
John
Old Mar 6, 2008 | 03:55 PM
Rolls's Avatar
Rolls
Mine sits a fraction under halfway, but only by the smallest of margins.. - Which equates to roughly 92 deg on the secs
Old Mar 6, 2008 | 04:12 PM
ECOS95's Avatar
ECOS95
As Said above mine sits just below half way. Goes up to where your saying on a Hot day when its been stood idling. The Fans should bring it back down to half way etc.
Might be your thermostat.
Old Mar 6, 2008 | 04:40 PM
cossymad's Avatar
cossymad
R-M
Old Mar 6, 2008 | 06:00 PM
NEIL A's Avatar
NEIL A
Mine sits just above the black block during normal driving , rising to '0' in trafic but drops back down as soon as moving again. Running a alloy rad around twice the size of standard.
Old Mar 6, 2008 | 07:07 PM
bigpower's Avatar
bigpower
Mines about half way
Old Mar 6, 2008 | 07:11 PM
bpspa's Avatar
bpspa
just ever so slightly over half way
Old Mar 6, 2008 | 07:22 PM
JohnP001's Avatar
JohnP001
Thanks for all the replies. I might just change the thermostat, but seems nothing to be too worried about.
Thanks
John
Old Mar 7, 2008 | 09:58 AM
mikedaf2's Avatar
mikedaf2
Thumbs up
Exactly the same as mine with ally rad but i did have hoter running temp with the standard radiator as it was semi blocked so try flushing your rad and heater matrix.
Old Mar 7, 2008 | 10:33 AM
Dave Henshall's Avatar
Dave Henshall
other point of failure could be the relay (big green one at the side of the battery) they actually switches the fans on from off to lo to high. mine was full of water and the inners had rotted out leaving only the high speed working whihch in turn caused the temp to rise up before the fans kicked in. i eventaully replacee the relay and fitted a 2wd stat so that the fans came in at high speed straight away at the lower setting.
Old Mar 7, 2008 | 10:48 AM
krisberic's Avatar
krisberic
Is there a way of checking if high speed and low speed works.
Old Mar 7, 2008 | 03:37 PM
Dave Henshall
easyest way is to go for a run then leave it ticking over, the fans should come on low at first , hold it revving at around 3K for a couple of mins and then they should kick in high and switch off once down to temp again.
Old Mar 7, 2008 | 03:43 PM
AlexD's Avatar
AlexD
Post Miester !
I realised not so long ago that althought i dont have the air con anymore, the switch still turn the fans on the slow speed setting, very handy for keeping it cooler in traffic.
But yes mine sits in the middle too, normally.
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
