What size disc's?
Oct 18, 2004 | 08:07 PM
What size disc's?
Im after a set of Wilwood front brakes for my S2 Escort Turbo. Anyone know what size disc i can fit under the standard rims 260/283mm??
Oct 18, 2004 | 08:56 PM
Oct 18, 2004 | 10:17 PM
ive got 283mm on standard rims
Oct 18, 2004 | 10:24 PM
i had 283mm but needed spacers for the wheels to clear the caliper on the back of the rim
Oct 18, 2004 | 10:26 PM
Did you use cossie discs and were they 2wd or 4wd?
Oct 19, 2004 | 08:28 AM
2wd cossie discs
Oct 19, 2004 | 05:25 PM
2wd discs should be fine dont know why you had to use spacers
Oct 19, 2004 | 06:37 PM
2wd cossie discs on mine with the wheel balnces inside the rim and they're fine
Oct 20, 2004 | 02:25 PM
caliper was catchin on the back of the rim
Oct 20, 2004 | 06:26 PM
i've got 283mm disks 2wd cossy ones and mondeo st24 callipers they did'nt need spacers
Oct 20, 2004 | 07:18 PM
im runnin willwood dl 2 4 pots with 2wd cos discs (283mm) behind std s2 wheels and have had no probs
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
SMILER258
Sep 28, 2015 09:04 AM
