Fans just blowing out HOT air???
My other half's Ford Ka has started blowing out just hot air from the heater vents in the car, even when the control is set to it's coldest setting, and also with the air con switched on it makes no difference!
What could cause this, would it be a heater matrix type issue???
I've checked the water level to make sure it's not overheating and it was ok.
I beleive that the hot cold bit is water tap controlled on these(but could be getting mixed up), so that is needing to be looked at, they often fail and are on the bulkhead easy to fix, or was it later fiesta's ?
Make sure you get the latest level heater valve , there are 3 different types the last is the best ... the first is almost as good ..... but the middle one stay clear of .
It is correct that the control does go faulty , but only in about 5% of cases so go valve first
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
