best chip for 803's
hi there , does anyone knows who does the best chip for escort cosworth t34 wth 803's, and what is the highest figure you can get with them !
many thanks
many thanks
Get a Closed Loop Chip From Motorsport Delevopments !
Mine Made 360 BHP at 25 PSI Only real engine mod is a ported head, so yours should be around 340 BHP imo.
Easy to install and setup..
Normaly, every chip must use it.
The GGR uses the standard 2.5bar Map sensor, and you have to recalibrate the waste gate.
For my car, as my solenoid's dead, I'll use a bigger collin's 31 WG with a bleed valve to regulate around 1.3bar (looking for reliability
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
