Escos Air Con
Old Mar 2, 2008 | 12:31 AM
turbomook's Avatar
turbomook
Default Escos Air Con
I was just woundering is it possible to connect the air con back up using a Rs500 cooler? Ive heard that i would need a new style cooler, but im not sure what make? and if its much hassles etc?
Is it something worth doing?
All comments appriciated, Thanks
Old Mar 2, 2008 | 09:33 AM
AJC's Avatar
AJC
the radtec style 500 cooler allows you to keep air con, thats all im aware of
Old Mar 2, 2008 | 10:00 AM
GUZZLER's Avatar
GUZZLER
so many different stories about a/c & a 500 cooler, for now i have left mine on a standard charge/intercooler with a pace upgrade. When the weather warms up a bit & get some motorvation i'm thinking of trying to mount a 500 cooler infront of the a/c rad, that way the cooler will have a better flow of air, the a/c will not work as well but it should still do its job!
Old Mar 2, 2008 | 11:23 AM
THE RADMAN's Avatar
THE RADMAN
yep, radtech do the kit, around Ł650 though thats what i fitted to mine,very tight fit,bit of fettling reqd but it seems to work ok
Old Mar 2, 2008 | 06:32 PM
turbomook's Avatar
turbomook
Thanks for the advice
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
