Waterfeed pipe Cosworth t3
You'll be lucky to get them from Ford now, i bought the one thats nearest to the head recently, it was around £80 i think and that was with staff discount.
You can get these braided ones off ebay though...
http://cgi.ebay.co.uk/SIERRA-RS-COSW...QQcmdZViewItem
You can get it SILVER SOLDERED, it will be MUCH stronger than the ford OE ones then.
Ford do no longer supply them.
Silver solder does not sound strong, but when trying it out, it could not be snapped at all, the pipe broke before the joint.
A tip, I also welded a 15mm NUT/S to the HEX heads of the banjo bolts so dead easy to get spanners on now.
mine snapped a while back,my pal welded it with a normal welder,didnt look too pretty but it held ok,i bought a brand new 1 at the same time,think it was about £30!i cant remember but i would not have paid £80 for 1.i got it off ebay,cant remember which seller either!
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
AndrewStrang
Sep 1, 2015 11:16 AM
Aug 14, 2015 07:29 AM
