idle screw, is this 4wd or 2wd
i need an idle screw for my throttle body as mine is seized solid
so while the engine is aprt im going to get the screw machine out and hopefully get a new one in there
this is teh only one ive found but is it a 4wd as it looks like a 2wd to me
http://cgi.ebay.co.uk/GGR316-Coswort...QQcmdZViewItem
or does anyone have a 4wd idel screw lol
Is that not a 4wd one? They go 'inside' the idle screw hole on the throttle body - needing an O ring. 2wd ones poke out the throttle body and therefore do not need an O ring - but they do have the nut?
Maybe someones just put a nut on a 4wd one?
2wd one:
http://cgi.ebay.co.uk/GGR428-2wd-Cos...713.m153.l1262
See how long it is it to 'poke' out the throttle body.
I reckon someone has had a mad moment and just stuck a nut on a 4wd one.
Sorry mate,hadn`t even looked at the link..
That is the correct one,the 2wd one doesn`t have the o-ring,for some strange reason you get the nut as well,even though you don`t need it.
looking again, the 1st one is a4x4 one - BUT with a lock nut which is definately a 2wd bit, the 4x4 one as said above screws in almost hidden into the throttle housing
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
