Is a 70AMP Alternator enough for a 2wd Cos?
Old Feb 29, 2008 | 08:47 AM
boXXer's Avatar
boXXer
GASH!
Default Is a 70AMP Alternator enough for a 2wd Cos?
Reason i ask is, my local motor factors have the 70AMP in stock, but not the 90AMP, but the light came on today on the way to work, and i need to change it. Do i need to look around for a 90 or will the 70 be enough?
Cheers!
Old Feb 29, 2008 | 08:48 AM
silky16v's Avatar
silky16v
Get on That!
Cheers!
how much is the replacement alternator cause you'll find if you get your own re-conned it'll be cheaper i had mine completely over-hauled for £50
Oh it 90amp
Old Feb 29, 2008 | 08:51 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
No. Has to be a 90 amp one, or you run the risk of the car running lean under high load with lights / stereo / fans / heater fans etc running.
Old Feb 29, 2008 | 08:53 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
can you answer my PM Mike please?
Old Feb 29, 2008 | 08:58 AM
Sticky.'s Avatar
Sticky.
Jasesaphy has a 100amp one for sale a week ago Mike. £65delivered IIRC.
Old Feb 29, 2008 | 09:00 AM
Mike Rainbird
Caraholic
I'm just putting a 145amp one on mine, as the 90 amp one is not sufficient for three fuel pumps....
Old Feb 29, 2008 | 09:06 AM
Ryan's Avatar
Ryan
i need to uprate mine now from 70 to 90A, 70 is for 3drs, as they dont have heated front screens, and a few less electrics
Old Feb 29, 2008 | 10:29 AM
boXXer's Avatar
boXXer
GASH!
just taken the original ford one off, and its actually a 70amp one. So im gunna replace it with the same. As Ryan has said, the 90's were for cars with more electrics.
Old Feb 29, 2008 | 10:30 AM
boXXer's Avatar
boXXer
GASH!
balls. Just paid £65 for a recon one. Mind you, i dont have a choice ATM, as im stuck at work with it, lol.
Old Feb 29, 2008 | 11:58 AM
70 is plenty, no alternator will put out CONTIUOUSLY it's rated power, it is a peak, much more than about half the rated power and they will get too hot, and fail.
If you want a more powerful one just get it rewired in DELTA ,as opposed to STAR.
DELTA will give more current than a star connection.
Old Feb 29, 2008 | 12:10 PM
RST-AndyP's Avatar
RST-AndyP
as said 70amp is fine,total bollocks about 90amp leaning the engine with everything on.
Old Feb 29, 2008 | 01:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the lower spec cars had 55amp alternators, then they jumped up to the standard 70 amp and the higher end ones had the 90 amp versions
if you are stuck you can always opt for the granada version which will bolt on if it's the correct version listed if you want it, besides, it's not as if you will notice any increase in getting hte 90 amp one but you may notice it with a 55 amp little diddly version
changed on about a year ago and the 55 amp one came out easy enough but the 90 amp one was much bigger physically and wouldn't slot through the same gap
Old Feb 29, 2008 | 02:59 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
once gain some great passion fruit advice on this forum!!so many experts here......
Old Feb 29, 2008 | 03:40 PM
dojj's Avatar
dojj
my grocery information is correct as far as relating to the amperage of the various alternators as found on the engines fitted to some ford sierra's is concerned thank you very much
unforutnatly, the uk spec cars came with 70 and 90 amp versions, the 55 amp one was from a dohc 90 spec car from hungary or the like
Old Feb 29, 2008 | 05:20 PM
col cos1's Avatar
col cos1
ever since ive had my car the battery light comes on when first running until you give it a rev,just like the old transits lol
ive changed it and it still does it
Old Feb 29, 2008 | 06:25 PM
boXXer's Avatar
boXXer
GASH!
They all do as far as im aware mate. It doesnt go out till it hits a certain Voltage, then switches off after that preset voltage. Its like a alternator voltage checker.
Old Feb 29, 2008 | 06:43 PM
CossieRich's Avatar
CossieRich
That must just be a 3dr thing as my saff has never done that
Old Feb 29, 2008 | 06:45 PM
boXXer's Avatar
boXXer
GASH!
fook knows? i thought all alternators did that, as they dont hit full voltage to 1800 RPM or so. I think it depends on how high your car revs on choke/cold start.
jonfoc
16
Sep 11, 2018 05:35 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
coscor86
Sep 20, 2015 01:21 PM
