Quick Q about calipers?
Old Feb 29, 2008 | 04:07 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Default Quick Q about calipers?
Took my Cossie for a service and wanted the break fluid changed as it aint been done for 4 years!
Bloke at the garage said that the nipple on the calipers was seized and he didnt want to attempt to release it to change the fluid in case it broke!
As i`m not mechanically minded in any way just wanted to know if he was bullshitting me because he didnt want to do the job or is he correct, the nipple might break?
If so what are my options? Worse case, new calipers?
Lee
Old Feb 29, 2008 | 04:38 AM
stevecossy's Avatar
stevecossy
The nipples can be seized and sometimes will break but sometimes come out with a bit of heat, as ya say worse case is new calipers but they are not too expensive exchange.
Old Mar 1, 2008 | 12:16 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Cheers stevecossy, does explain it as the garage dont want to keep my car over night for insurance reason
Old Mar 1, 2008 | 05:53 AM
NOT uncommon unfortunately, some people tighten them way too tight.
If you did need calipers, BIGGRED.CO.UK
Old Mar 2, 2008 | 03:31 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Thanks tabetha, I get a discount at Quickco so i`ll see how much to replace my standard Ford jobbies
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
