Overboosting...???
amal valve controlls the actuator electronically.
Also check the vacum pipes from plenum to amal..then from amal to turbo if any come off or split then actuator will not open when it should making it overboost.
Dan
Dan
when i first got mine on the road there was a pipe off the amal valve, the one that goes to the actuator, it was tring to boost 30+ psi, went like it had a rocket up its arse untill it missfired!
fuelling is not set for extra boost = melted engine worst case scenario!
If its extreme like my was, then its not really good for anything, the turbo is just boosting what it can, no actuator control at all, could result in dead turbo and engine.
