editing threads
copied from the FAQ's - looks like it is only possible on your last post within a thread sort of thing :
If you have registered, you will be able to edit and delete your posts. Note that the administrator can disable this ability as he desires. Your ability to edit your posts may also be time-limited, depending on how the administrator has set up the forum.
To edit or delete your posts, click the
button by the post you want to edit. If your post was the first in the thread, then deleting the post may result in the removal of the entire thread.
After you have made your modifications, a note may appear, which notifies other users that you have edited your post. Administrators and moderators may also edit your messages but this note may not appear when they do so.
button by the post you want to edit. If your post was the first in the thread, then deleting the post may result in the removal of the entire thread.After you have made your modifications, a note may appear, which notifies other users that you have edited your post. Administrators and moderators may also edit your messages but this note may not appear when they do so.
on certain versions there is a time limit to think abot as well
and if this is set too low then it just doesn't work because b the time you've made the edit the times run out
DavidK
Sep 27, 2015 02:55 PM
im off editing before it disappears again
