cosworth coil pack conversion
Old Feb 27, 2008 | 05:16 PM
155lee's Avatar
155lee
Default cosworth coil pack conversion
can you use coils from any ford in this conversion?£400 seems a bit steep for a kit and my friend is an auto electric whiz who could make something similar up for a fraction of the cost!anybody made up their own and want to share the info?
Old Feb 27, 2008 | 07:11 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Did mine for around £150 i used a 1.6 escort zetec coilpack and cut the
ends off my oe leeds and fitted the coil pack terminal ends.
already had a second ignition amp with heat sink
the only parts that i had to buy were the coil pack driver board (89.99
from msd via ebay)
and the sub loom (50.00 off ryan)
Old Feb 28, 2008 | 08:58 AM
The cost is ONE of the reasons I decided to junk the piece of crap ecu, and go aftermarket with direct coilpack drive, ie no amp(external), when you add closed loop etc aftermarket ecu looks good value.
Hellraiser
Aug 30, 2015 10:29 AM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ricky
Jul 31, 2015 10:30 PM
