2wd abs master cylinder
The 2wd and 4wd master cylinders had the sphere on opposite sides of the fluid reservoir.Can i fit either to my 2wd.Are they interchangable or do you have to change like for like?Is the xr4x4 the same unit,it looks the same?
Many thanks
Many thanks
