Front mount, which one?
Old Feb 24, 2008 | 12:15 PM
becca s2rs's Avatar
becca s2rs
Default Front mount, which one?
Got a 90 spec s2, want to fit a front mount cooler just wondering which one is the best?
Was looking at the Autospecialists one but have heard that its crap and people have sent there ones back due to loss of power.
What one would you guys recomend? and what sort of price with twin fans?
cherRS
Old Feb 24, 2008 | 12:19 PM
turbo.jon's Avatar
turbo.jon
Thumbs up
Grs
Old Feb 24, 2008 | 12:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
GRS or Radtec, IMO.
Karlos.
Old Feb 24, 2008 | 12:47 PM
antony215's Avatar
antony215
Escort Rs Turbo
GRS
Old Feb 24, 2008 | 01:56 PM
jessie_rs's Avatar
jessie_rs
as above!
Old Feb 24, 2008 | 01:58 PM
addiction's Avatar
addiction
GRS
Old Feb 24, 2008 | 02:16 PM
gus's Avatar
gus
custom?
Old Feb 24, 2008 | 02:17 PM
rsdan123's Avatar
rsdan123
pro alloy single pass, its about £100 more than the grs but its single pass so you get better flow!
Old Feb 24, 2008 | 02:19 PM
Jay,'s Avatar
Jay,
Sponsor
pro alloy always suffer with high air temps ! give rapidford a bell get urself a radtec
Old Feb 24, 2008 | 02:21 PM
rsdan123's Avatar
rsdan123
really didnt know that, the one i had was fine car never over heated and didnt ever get detination once the car was set up.
Old Feb 24, 2008 | 03:06 PM
Andy_R's Avatar
Andy_R
GRS.
And if you need a single pass IC Graham can sort you out with one too.
GRS Website
Old Feb 24, 2008 | 04:10 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
had a grs, cant see how it could be beaten, a pleasure to own
Old Feb 24, 2008 | 04:29 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
iv got a pro alloy n never suffered from high temps, as i have a temp gauge 4 it!
Old Feb 24, 2008 | 04:59 PM
gus's Avatar
gus
i think the pro alloy one depends on what sort of power levels your at
i use to have one and it didnt like big boost
having them do me a custom jobbie so this im sure will be spot on
Old Feb 24, 2008 | 05:04 PM
B1G_RST's Avatar
B1G_RST
radtec
Old Feb 24, 2008 | 05:12 PM
RAT8OY's Avatar
RAT8OY
RADTEC,
Dont forget there is more to it than the inlet temps alone. How well does the front mount allow the rad to get a share of the cold air?
Radtecs are designed with this in mind. You will see if you look at the type of core they use compared to others.
Old Feb 24, 2008 | 05:14 PM
DazC's Avatar
DazC
Was out on Friday night in AJC's RS1600i trying to find out why we can't run more than 6 degrees ignition advance without det starting. Did a datalog run and then watch some alarming figures in real time.
These figure were air charge temps. They were rising as fast as the boost pressure and this was on a Pro Alloy single pass cooler on a T34 at 26 psi boost. 65 degrees C peak temps. As soon as it came on boost the temps just shot up.
Old Feb 24, 2008 | 10:08 PM
rsdan123's Avatar
rsdan123
26PSI!!!! i was not running that sort of spec, i was running 14psi on efi OFAB with 195 chip beige injectiors and stg3 t3 and it was fine
Old Feb 24, 2008 | 10:23 PM
rstdave's Avatar
rstdave
Daz C....blimey that's sky high, not runnin that boost but at 1.5bar on a stg3 t3, act's don't go over 40 on the hottest summer days as long as you're goin along at a fair pace (even on track) with my grs! 6 degrees advance ain't much is it....with lower act's and some more advance it'll be alot quicker lol.... when mine goes into the 50's it's noticably alot more lethargic and loses it's snappiness.
Old Feb 24, 2008 | 10:44 PM
JamboRS's Avatar
JamboRS
focus rs 1672
custom single pass if money isnt an option,doesnt need to be full front mount to get good act's, check out t28rst on here,retains std fan and plenty of airflow to rad plus never see's act's over 28-30,cant ask for more than that
Old Feb 25, 2008 | 12:04 AM
DazC's Avatar
DazC
I've backed it off from the peak 34 and held 29 psi boost it was running and increased the fuel to try and help keep the charge temps down a little and det at bay. Seems like the pro alloy cooler is ok to about 18 ish but after that it's on it's knees.
We're looking at ditching it for a grs but the lead time is a little offputting. Need to check how long. The car needs more advance than 6 degrees. It's quite lively with the boost going through it but it'll be a lot better with advance.
Old Feb 25, 2008 | 01:28 AM
RAT8OY's Avatar
RAT8OY
Well I am sure to be corrected on this but my last ZVH was making 294bhp and 354lbft of torque and with my custom made Radtec single pass the highest I got was around 53 degrees but that was under load. back off for a few seconds and it would drop straight off! The Radtec chargecooler I had was a load of pants and was well over 80 degrees at 20psi.
Old Feb 25, 2008 | 07:08 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
GRS twin pass without doubt
Old Feb 25, 2008 | 09:18 AM
bonus_boy's Avatar
bonus_boy
grs evo 2 with twin 10" kenlowes....
would defo go back to that setup!
Old Feb 25, 2008 | 04:54 PM
bezo's Avatar
bezo
powered by K26
Originally Posted by Andy_R
GRS.
GRS Website
yer like andy says, give graham a bell hes a top chap and will help you out!
Red_bull
Aug 25, 2015 06:27 PM
C2 MAK
Aug 20, 2015 09:46 PM
Escortdriver1
Aug 19, 2015 09:02 PM
dal3door
Aug 13, 2015 06:55 AM
