boost setup of e T28 cosworth
Old Oct 17, 2004 | 10:31 PM
danielT28's Avatar
danielT28
Default boost setup of e T28 cosworth
Hallo
How should I set the boost" BAR " of e escort T25 (28) cosworth whit e GGRstage 2 conversion (??1.5bar and hould 1.2 bar
Ps, my english is not so good, but I hoop you understand the most of it.
GREETINGS from BELGIUM D&L
Old Oct 18, 2004 | 06:01 PM
Cossie-Iain's Avatar
Cossie-Iain
You want to get a boost gauge fitted and set the boost in PSI.I think from memory I set my boost by removing the heat shield and then take the metal rod off at the wastegate end and turn it clockwise to your desired pressure.I think each turn of the rod is 1psi.
gchristophi
Aug 31, 2015 10:36 PM
jc1989rs
Aug 30, 2015 06:32 AM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
