cill's are fooked on my escos
Any expirieced panelbeater should be able to fix this easily, most esc cos let go at much wors places to repair. Like rear wheelarches, a-posts and around window and petrolcap.
Ive not taken pics of mine either mate, but mine are thankfully repairable without a full panel as i first envisaged, are they both bad or just one like mine?
looking on mine ford used fuck all rust protection underneath the kit on these cars so there will be a few more cars needing sills at some point
Cant explain why these go so badly, but as Dan says they didnt do anything about these for protection,if you look at how much of the rubbery stuff they put underneath i cant believe they didnt put any on the sills. I know they arent available anymore as when i discovered mine were gone i wanted to replace the sill but fortunately mine can be patch repaired, can yours be too?
i hav th same problem lads was sending car away to get fixed, pulled of skirts and oh my god couldn't believe th rust just d.side is worst left sill not too bad thou.....
did anyone ever use th normal mk5 ones? would consider it thou prob need to drill out holes for th skirts shouldn't be problem though!!
I had some small work done to my sills
( .. and will need to get some more work done to the floorplan.
Is it possible to get new floorplans to the Escort Cosworth??
( .. and will need to get some more work done to the floorplan.Is it possible to get new floorplans to the Escort Cosworth??
