compression help
Old Feb 23, 2008 | 11:52 AM
juffer's Avatar
juffer
Default compression help
im currently doing a zvh and got some calculations with my compression im using standard rods with c20xe pistons can someone help with the blanks?
Bore 86 mm
Stroke 88 mm
Gasket Volume 8.71 cc
Ring land Volume ? cc
Piston Volume 3.60 cc
Head Chamber Volume 55 cc
Deck Volume ? cc What is DECK VOLUME? is this the
difference between the top of the piston and
the top of the block at full stroke?
does this look about right so far also if any one has done this using xe pistons can you help me out please, the deck vol and the ring land vol is all i need i think to get the comp?
Old Feb 23, 2008 | 04:19 PM
sas's Avatar
sas
should be good!
Bore 86 mm
Stroke 88 mm
Yes that looks right, but the piston dome is normally a negative figure, you are right for deck figure. You dont need to add the ring land volume as it is incoinsedantal.
S.
Old Feb 23, 2008 | 04:21 PM
sas's Avatar
sas
should be good!
Try this.
http://www.csgnetwork.com/compcalc.html
S.
Old Feb 23, 2008 | 05:16 PM
juffer's Avatar
juffer
why is the piston vol a negative as with a dished piston its allowing more volume.
thanks
Old Feb 23, 2008 | 05:27 PM
sas's Avatar
sas
should be good!
thanks
Yeh sorry it can be both, depends what calculation you are doing in relation to the deck height.
S.
Old Feb 23, 2008 | 05:34 PM
juffer's Avatar
juffer
oh, is there a simple explanation dont mean to sound thick
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
