Escort Turbo 4 pot Brembo kits
We have now fitted the same monster Porsche caliper we use in the Sierra 2wd kits to the Escort Turbo hub.
17" wheels required.
Compomotive wheels can have a 335mm x 28mm rotor / bell
The standard poor design RS 7 spoke will take a 315mm x 28mm rotor / bell.
Prices from £700
335mm rotor to show size of caliper.
Kits available from stock in Porsche Red / Yellow and the Carbon look calipers are on back order from Brembo (we wiped out UK stocks lol)
They have the quick change pad retainers which means you can change pads in under 30 seconds perfect for both road and track cars
Again prices from £700
Prices from £700
The E36 M3 does have a 6 pot 335mm x 28mm upgrade kit available Jay yes.
Its used on a few race cars
(still have your wheel here safe by the way
Off topic mate , i have a set of focus rs brembo's that i am about to fit to my series 2, they have been powder coated now and i forgot to take pics of the left and the right one, just wondering if the slightly bigger pots should sit at the top or bottom when mounted which mean the at the braided brake line would be possitioned closer to the top aswell.
cheers mate.
Ben
cheers mate.
Ben
i belive its the same as the fiesta/rs turbo, as the cossy brakes mount the same way, the st170/mondeo mrk3 calipers mount the same (drill the mouting holes to 12mm), everythign thats fits the fiesta will fit the ka
Mounting centres may be the same but are the heights and offsets ?
Sorry but I can't send out a kit on the belief or hearsay that it will fit, as even if its just 2mm out no amount of bending, pulling, pushing or shoving solid metal will make it fit. Remember we go from a standard offset single piece disc up to a proper veined and vented rotor/bell combo so the offset is very important.
If you have a hub off the car and can send it up I can build a kit up on it to confirm yes or no for you.
thats an amazing piece of ki! i am interested in a frond and rear kit for my 2wd saph cossie.my wheels are 7x17 and 8x17 comp mo's 6 spoke.do u do such a kit?if so what will be the cost?
Take a look here for the 2wd kit
https://passionford.com/forum/general-car-related-discussion/246733-new-brakes-big-thanks-to-nuts-rus.html
Or here
https://passionford.com/forum/general-car-related-discussion/236677-new-brakes.html
Just 2 of many
Price would be dependant on pad choice and specific delivery costs to your country.
What do you charge 2 make up some mounting brackets??
its for a polo gti, so u can go from the polo's 256m disks 2 a g60 280m disk?
sadly gewine g60 brackets are as rare as rocking horse shit! and the polo gti use's the same caliper!
would be for ten sets!
cheers!
cheers!
same as a g60 yes mate!
the set up on the polo gti is excatly the same! same hub, same caliper just uses a different caliper mount that takes 280m disks were as the polo use's a 256m!
Most people just gethold of the g60 caliper brackets but they are so hard 2 find now days and vw charge a forchune for them!
If you could make up a small adapter plate 2 push the polo caliper bracket and caliper out 2 except 280m disks i could sell loads of them!
