escoz doors
Old Feb 20, 2008 | 12:33 AM
andysrs's Avatar
andysrs
Default escoz doors
Anyone no if escoz doors are still available from ford??
Old Feb 20, 2008 | 05:30 AM
grcossie's Avatar
grcossie
Yes they are, it`s the same doors on other 3doors Escorts
Old Feb 20, 2008 | 11:19 AM
Paul_Painter's Avatar
Paul_Painter
I believe that additional sound deadner was added to the Cossie doors to give it a better sound as it shuts?
When I bought my car the LH door had been previously replaced due to an accident, when I took both door pads off, there was deadner in the RH but not the LH. I simply fitted a similar self adhesive deadner and they now sound and feel the same.
If you tap an original cossie door it sounds alot better than a 1.3 standard car.
Paul
Old Feb 20, 2008 | 04:59 PM
grcossie's Avatar
grcossie
That is not the door shell, it is the same part number as any standat 3 doors
Old Feb 20, 2008 | 05:04 PM
graham c's Avatar
graham c
all doors should have sound pads in them so it,s had i new door and the,ve not put one in, they dont come with the doors so who ever fitted the door never fitted the sound pad
Old Feb 20, 2008 | 06:18 PM
Rippers's Avatar
Rippers
Monte Geek
The doors are identical
chowfornow
14
Jan 5, 2019 09:01 PM
mpilk
Sep 27, 2015 09:21 AM
Vacuman
Sep 22, 2015 12:09 PM
Vincereese
Sep 18, 2015 12:48 PM
