Brakes - need to press them hard
It's been a while since I've had an rst and i recently got another one, I'm starting to get used to it again,but it seems that while the brakes do work you have to press them quite hard, I don't know if that's what they are like and I have been spoilt as my other car is a mk4 golf gttdi, or if I am missing something, as it doesn't really feel like there is any servo assistance?
As i said they do work fairly good but you really feel as if it is the force of you pressing the pedal that is making it stop, with no help from the car, bit like when you're being towed but not as bad, hope that makes sense, can't make my mind up if it should be like that
Also, the car seems a bit susceptible to following the bumps on the road and seems to sometimes wander slightly on the shite roads round here, again don't know if this is how they are or would it be the anti-roll bar bushes or something?
my brakes are pritty hard on mine i think thats just how thay are.
have you got uprated brake pads on yours, i remember i had a set or green stiff/stuff pads on mine and when thay were cold or going slow i though i was going into the person in front all the time
i would say the bushes aswell
if you need to press them abnormally hard then i'd say theirs a servo assistance problem.
following the road sounds like it could be:
Bushes
rack
steering coupling
tracking
Bushes
rack
steering coupling
tracking
I'd get it up on a ramp, lever all the bushes to see what ones have play in them.
as for steering, get it on a ramp, shake the wheels with lock off and feel for play/listen for knocking
Could be a few things best jus to check the whole front suspension/steering over!
A hard pedal is just a fact of life with these cars, a lot of effort is lost through slop in the brake linkage, flex across the bulk head, and excessive master cylinder sizes.
As for the road handling, that again is very common. I'm guessing you have the car lowered? And if it is, that will be the answer to your question.
