hydraulic clutch conversion
Old Feb 17, 2008 | 08:03 PM
stevieel's Avatar
stevieel
Default hydraulic clutch conversion
is there anyone other than burtons who do a hydraulic conversion for the 2wd sierra cossie box?
Steve
Old Feb 17, 2008 | 08:34 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Mr rainbird does them.
Bottom of page.
http://www.randbmotorsport.co.uk/sho...ID=3&offset=10
Old Feb 17, 2008 | 08:35 PM
purplemonster's Avatar
purplemonster
RWD PUMA :)
martyn also dose them
or make your own like i did
Old Feb 18, 2008 | 09:33 AM
stevieel's Avatar
stevieel
sorry for my ignorance but who is martyn?
Steve
Old Feb 18, 2008 | 04:54 PM
Simmo's Avatar
Simmo
http://www.reyland.co.uk/Details.asp?ProductID=56
Old Feb 18, 2008 | 07:45 PM
stevieel's Avatar
stevieel
thanks for that
Old Feb 19, 2008 | 08:21 AM
Niall.b's Avatar
Niall.b
i got mine from reyland. its a good kit but theres a bit of work to fitting it. the crucial things are getting the position of the master cylinder in the bulkhead right and the pivot bearing in the clutch pedal. if these are wrong you will never get a pedal. on the plus side operation is much smoother particularly with a paddle clutch
Old Feb 19, 2008 | 09:39 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: hydraulic clutch conversion
Steve
As already mentioned I do a kit (can fit if needed too) ... Give me a call if you need any further info 0121 458 6010, Martin.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
