v6 cosworth convesion
Old Feb 17, 2008 | 06:29 PM
Deanoxr2's Avatar
Deanoxr2
Default v6 cosworth convesion
hi i am new to passioford, i am thinking of putting a cosworth v6 in my sierra sapphire how easliy is this done and what type of gearbox should use? cheers
Old Feb 17, 2008 | 06:41 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
2wd or 4wd sapph?
Cheeers
Dan
Old Feb 17, 2008 | 06:46 PM
Deanoxr2's Avatar
Deanoxr2
2wd mate
cheers
Old Feb 17, 2008 | 07:00 PM
SillyFezzaMk1
Rubber Rhino Crew
you need to find a 2wd granada then to start with. pretty much all the parts are there.
Well pretty much all of the 2wd granada bits will go straight onto a saph.
Drop the lot out from underneath (rear beam, box, front x-member, arb, engine, rad etc..) do same on the saphhy and bolt it all back up.
Keep the loom from the granada and get a decent sparky to wire it in for you (bit complicated to do it yourself unless your very handy with wiring)...I can reccomend someone if your in east mids.
using the full underside of the granada means you get a LSD in the rear and the conversion can be done in a day by a competent garage.
Dan
Old Feb 17, 2008 | 08:10 PM
Didnt the cossie v6 granada engine come with the auto box only.
Old Feb 17, 2008 | 08:31 PM
SillyFezzaMk1
Rubber Rhino Crew
I'm sure i've seen rwd mt75 int eh granadas...I dunno maybe someone can clear it up....
Dan
Old Feb 18, 2008 | 08:07 AM
I always thought they were automatics cause u had to us a flywheel off another car for the manual box.
Old Feb 18, 2008 | 08:11 AM
SillyFezzaMk1
Rubber Rhino Crew
Well i'm sure that the rwd mt75 box came fitted to a v6 24v engine....it must have come in some variant.
tbh the options for rwd are rwd mt75 or T5 (with adapter brkt...topboss do them IIRC)
I've only ever done the conversion on 4x4 sierras which is a piece of piss. Ford did a 4x4 granda and a rwd granada 24v I'm sure of it....i'll go check as its bugging me now.
Dan
Old Feb 18, 2008 | 07:51 PM
Saaamon's Avatar
Saaamon
Dan
i thinking of this conversion on my saff 4x4 how hard is it get hold of a 4x4 granada and what gearbox do you use to convert to manual
Old Feb 18, 2008 | 08:25 PM
SillyFezzaMk1
Rubber Rhino Crew
Dan
What model of saph is it?
Dan
Old Feb 18, 2008 | 09:29 PM
Saaamon's Avatar
Saaamon
its a saff ghia h reg 2.0
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
